NH 758C Back Hoe on 40 Boomer ..hyd hoses going
   / NH 758C Back Hoe on 40 Boomer ..hyd hoses going #1
halm
exeter, ri
ford, new holland, yanmar
Had 1 hose, 140" split this winter. Replaced and almost at once had 4 more split at bottom on boom. Just age or am I looking at increased pressure ?
Help appreciated.
   / NH 758C Back Hoe on 40 Boomer ..hyd hoses going #2
Help appreciated.
Had this same hose fail this winter. My machine is 14 years old and has aprox 600 hours, (with about 400 of those digging with the backhoe). Another member had replaced his by running a much shorter hose on the outside of the boom, which is what I have also done. I am not sure where the hose let go, (couldn't tell by looking in the boom), probably won't find out until I separate the dipper from the boom. Bill C
Well, it is right where all 6 hoses turn to go up the boom. All the same age, except for the 1 new, so it is possible that 4 of the 5 remaining
could fail at once, but doesn't seem likely. All I can think of is excess pressure, but why. Also it looks like the cylinder in the boom will have to be removed to get to the hose connections.
Mine is 10 years old, about the same hrs.
Thanks, Hal M
   / NH 758C Back Hoe on 40 Boomer ..hyd hoses going #4
old hoses, they don't last forever. bottom of the boom is where all the bending/ flexing is done
That is the worst place for flex and twist. Will "invest" in new, and we'll see if age was the only issue. How about the cylinder in the boom ?
Remove at both ends ? ugly !
   / NH 758C Back Hoe on 40 Boomer ..hyd hoses going #6
if your talking about removing the hoses you can use crow foot wrench for the hard to reach ones. tie a rope to the hose before you pull it out and you can pull the new one in
2019 FREIGHTLINER M2 26' BOX TRUCK (A51247)
2019 FREIGHTLINER...
Tiger Mower Hydraulic Tank Connection (A51691)
Tiger Mower...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2022 John Deere 8RT 410 Tractor (A53342)
2022 John Deere...
2019 JOHN DEERE Z960M ZERO TURN LAWN MOWER (A51247)
2019 JOHN DEERE...
12' CONTAINER (A51248)
