3 pt trailer hitch receiver on quickhitch
   / 3 pt trailer hitch receiver on quickhitch #1
planters49
Bobcat 122
   / 3 pt trailer hitch receiver on quickhitch #2
They are not made to quick hitch or 3PH standards. But some QH's may work if the top hook can be adjusted high enough. Standard 3PH vertical pin space is 18 inches, and 15 inches for a QH. These are 19.
Bruce
   / 3 pt trailer hitch receiver on quickhitch #3
Omni Mfg. has two styles that fit Quick Hitches. OMNI Combo 3 point Trailer Hitch Imatch Compatible - OMNI Mfg LLC
This is the Combo
I have the transformer.
The trailer weighs 5,000 pounds, weight on the ball is 1150. :shocked:
   / 3 pt trailer hitch receiver on quickhitch #4
A lot depends on the trailer weight. I sent the seller of a similar item on eBaya question about the material for the horizontal member. That particular one was "C" channel, not square tubing. I didn't buy it.
I wonder about (hence the trailer weight comment) a 3 pt being generally designed for extension forces which is fine if you're pulling the trailer. When backing up a trailer there is compression on the hitch. If the trailer is heavy, maybe a wheel drops in a rut, or you back into an immovable object can damage to the 3 point components occur?
There could be control issues as well since the 3 pt. isn't a fixed point. I pull my log arch using the 3 point rather than drawbar, but 8 MPH is about top speed because the wheels aren't well aligned and it will get moving the tractor side to side pretty good.
thanks for the help everyone
   / 3 pt trailer hitch receiver on quickhitch #6
If you used your draft sensing the steeper the hill you back up the higher your 3pt would lift :) A lot of ground engaging implements compress the top link, it's designed for both compression and pulling.
   / 3 pt trailer hitch receiver on quickhitch #7
John Deere 1025R (A53317)
John Deere 1025R...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
Deere 35G (A53317)
Deere 35G (A53317)
