John Deere 332 Yanmar Diesel
   / John Deere 332 Yanmar Diesel #1
metro
Sarahsville Ohio
Ford 4000
Engine starts easily but after 15/20 minutes run time it begins to lose RPM's, starts smoking and eventually quits running.
Installed new inline fuel pump and 2 injectors. Same problem.
Open for repair ideas. Thanks
   / John Deere 332 Yanmar Diesel #2
:welcome: to TBN
Have you opened the fuel tank cap to see if there is a plugged vent? Try this the next time you detect it losing rpm's.
   / John Deere 332 Yanmar Diesel #3
:welcome: to TBN
That's where I would look first ---- I would also check for a plugged fuel filter.
   / John Deere 332 Yanmar Diesel #4
Reading a similar issue on another forum, it turned out to be the fuel filter plugging up from microbial growth in the fuel.
For example:
Bacteria in Diesel Fuel - Diesel Engine Problems - MyCleanDiesel.com
You might need to get a fuel system cleaner and a couple new filters. Add the cleaner, run it with a new filter, then change the filter again after a few tanks.
Here's the thread in another forum; page two has the pertinent info near the end of the thread:
http://www.****************.com/forums/sub-compact-utility-tractors-scut/19616-2305-misbehaving.html
HTH!
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2017 PJ Bumper Pull Equipment Trailer (A53117)
2017 PJ Bumper...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
John Deere PT Land Leveler (A50123)
John Deere PT Land...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
