losing fluid out of the right rear wheel axle
   / losing fluid out of the right rear wheel axle #1
jim means
Olympia,Washington
Yanmar 2000
Losing fluid out of the right rear wheel axle does anyone have more information on the how to's of changing the seal or could it be something else..
   / losing fluid out of the right rear wheel axle #2
Common problem that a lot of us has had to replace them. Including me. Pretty straight forward just pull the hub with a wheel puller and then your be able to get to the Seal. A lot of us also has had to replace the collar. I didn't and had a drip or two after I used it. But that has seemed to have quit after I must to have over filled the Hyd. Fluid a little. Clemsonfor done his collar and don't recall there being any thing difficult about it. Hoye has a parts dia. to look at. But a lot of things are possible how much Hyd. fluid are you losing?
   / losing fluid out of the right rear wheel axle #3
It kind of depends on what kind of fluid you are losing. Those seals don't hold water very well.
Thank-you for the information just bought the tractor and i am still getting to know it i imagine it will take some time glad to have found this site...Again thank-you Jim Means
   / losing fluid out of the right rear wheel axle #5
I did mine. It was an easy job and the parts were less than $20 i think? I did a write up on it and put it here. Let me see if i can dig that post up.
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
20ft Driveway Entrance Gate w/ Deer Design (A57454)
20ft Driveway...
2008 Pace American 16' Cargo Trailer (A57148)
2008 Pace American...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
2025 Swict 78in Bucket Skid Steer Attachment (A56857)
2025 Swict 78in...
