Horse Manure as fertilizer ?
   / Horse Manure as fertilizer ? #21
If the horse manure is not over a year old it will contain bedding (shavings, sawdust) that hasn't composted. In the garden, the bedding will soak up the available nitrogen as it breaks down. The trouble with that is that it will starve your vegetables of nitrogen.
That is true, the carbon (wood) binds up the N, BUT! Once the carbon is composted out, it RELEASES the N, so you get it back...
BTW, I'd take all the horse poop I could get! Personally I get all the turkey poop I want, and most all the cow poop I want too, but I'd not turn down available horse poop!
SR
   / Horse Manure as fertilizer ? #22
I believe the horse poop is the only good thing about horses! Yes, as others have correctly stated, horse manure will have more seeds than cow. Good composting will greatly reduce that. I turn my piles about 8 times before using.
   / Horse Manure as fertilizer ? #23
I put it straight into the garden between the rows, then cover it heavy with grass... I don't care what kind/amount of seeds are in it, they never have the chance to grow!
SR
   / Horse Manure as fertilizer ? #24
Ive tried it in the past with no luck. First off, if the horses are fed grass hay expect lots of grass and weeds. If there fed an alfalfa diet, the manure wont have the weed issues.
My horses eat grass hay.
Second, i composted a pile for 2 years then ran soil tests on pile. All i could get were trace P and N. Not very impressed with quality of fertilizer.
Tested some steer manure... Off the charts.
Ill stick to the bagged steer manure. Also, its weed free
   / Horse Manure as fertilizer ? #25
SR
your a poop-a-holic
   / Horse Manure as fertilizer ? #26
your a poop-a-holic
AND proud of it!! lol
SR
   / Horse Manure as fertilizer ? #29
Thats nice Rob! You EAT all that stuff?
I'm envious of folks living the good life on the land.
Naaaaaa, we leave the poop behind!! ha ha ha
I have two fair sized gardens and we do can/freeze for the winter months... The pict above is of my front garden, here's the back garden,
Both picts are from last year...
SR
   / Horse Manure as fertilizer ? #30
I tilled in some fairly fresh horse manure in the garden once a couple years ago. I don't plan to ever do it again with fresh. It was full of viable grass seed. With the composted stuff you shouldn't have much of a problem. I just got some from my neighbor that has been composting for a coupe of years. Hopefully this weekend I can get it spread over the garden. I had planned to till it in but couldn't get it until after the garden had been planted. It may or may not not work miracles. The benefit will depend on what nutrients are in the composted manure and what nutrients the soil is in need of. I also have some partially composted sawdust that I am going to put in the middles with a little MAP sprinkled under it. That will get tilled on to the bed next spring.
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A53473)
GOODYEAR SET OF...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A51247)
2000 TRAILKING...
2022 COSEN INTERNATIONAL INC V-1822 BAND SAW (A51248)
2022 COSEN...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
