Smokin' deal on 10,000watt generator $649 (Today only)
   / Smokin' deal on 10,000watt generator $649 (Today only)
Yup, they are over rating that gen set....but that's what get's them sold!
SR
Hey you might be onto it,,,, sorta. This is really an 8,000/10,000 generator labeled as 10,000. Maybe that's why they have to dump them for $649. If that's the case I suspect they will come up for dumping again.
   / Smokin' deal on 10,000watt generator $649 (Today only) #34
Well it's here already. That was pretty darn quick for freight shipping especially considering where I live. No visible damage to box. I should get time this weekend to fire it up (assuming I got all the parts and it actually works)
   / Smokin' deal on 10,000watt generator $649 (Today only) #35
Got it unpacked and everything looks like it's there. I was impressed that it had a battery and included the wheel kit. I have one stripped screw on the bottom of the 110v outlet, no big deal. I dumped in a quart of some Pronto brand sae 30 oil. Screwed the Fitting on the propane bottle and purged the line. Cranked about 2 seconds and fired right up. Tested the 120v outlet and everything works. Voltage goes to 240 when you flip the switch. Idle control works as well. It included a bunch of plugs for the outlets and some basic tools as well as a funnel.
I ran it about 5 minutes and checked the oil and could see a few small metal flakes. I dumped it out and poured in a fresh quart. Ran that about 5 minutes and did another change. Oil looks good. I'll run this dino oil until I use it a few times and put some hours on the machine and then switch to synthetic. I'm really curious to see how this will run an inverter welder. I am going to pick up the necessary parts tomorrow.
   / Smokin' deal on 10,000watt generator $649 (Today only) #36
Got it unpacked and everything looks like it's there. I was impressed that it had a battery and included the wheel kit. I have one stripped screw on the bottom of the 110v outlet, no big deal. I dumped in a quart of some Pronto brand sae 30 oil. Screwed the Fitting on the propane bottle and purged the line. Cranked about 2 seconds and fired right up. Tested the 120v outlet and everything works. Voltage goes to 240 when you flip the switch. Idle control works as well. It included a bunch of plugs for the outlets and some basic tools as well as a funnel. I ran it about 5 minutes and checked the oil and could see a few small metal flakes. I dumped it out and poured in a fresh quart. Ran that about 5 minutes and did another change. Oil looks good. I'll run this dino oil until I use it a few times and put some hours on the machine and then switch to synthetic. I'm really curious to see how this will run an inverter welder. I am going to pick up the necessary parts tomorrow.
Nice report. Keep us posted.
DId you get the "DIGITAL HOUR / VOLT METER" ? Mine has only an analog meter. It has a "needle" that actually "moves" to 120 or 240VAC, remember those? :laughing:
   / Smokin' deal on 10,000watt generator $649 (Today only) #38
Analog. It's old school. Clearly not what was advertized but not a big deal IMO.
I wanted the hourmeter.
   / Smokin' deal on 10,000watt generator $649 (Today only) #40
True, i missed that part. Analog volt meter is not a big deal but an hour meter would sure be nice for things like oil changes.
2021 K and K System MB3L S/A Solar Towable Message Board (A55851)
2021 K and K...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
2021 CATERPILLAR 304E2 (A53317)
2021 CATERPILLAR...
2018 Dodge Grand Caravan SE Van (A55853)
2018 Dodge Grand...
