Can anyone tell me what conversion fitting would fit my current valve from this site
   / Can anyone tell me what conversion fitting would fit my current valve from this site #1
acadian32
Ottawa
Jinma 254
Good evening all, can anyone tell me what conversion fitting I need from this store world wide metric?
I have yet to find specification info for this FEL valve as to thread size and fitting type. thank you all.
   / Can anyone tell me what conversion fitting would fit my current valve from this site #2
That appears to be a 14mm ORFS on the power beyond port. What are you trying to do?
Good day Bob, I have a leak at the elbow joint well a drip so because those are odd size was thinking of getting conversion fitting from the at store I mentioned above see pictureValve leaking.jpg
and no I not planning on replacing the engine just jocking because as you know parts are not locally available in Canada :) pain in the """
   / Can anyone tell me what conversion fitting would fit my current valve from this site #5
Good day Bob, I have a leak at the elbow joint well a drip so because those are odd size was thinking of getting conversion fitting from the at store I mentioned above see pictureView attachment 425223
Did you put a new O ring on when you put the hose back on?
Hello Xfaxman, the only o-ring that I know of is the one you see on the picture is there another o-ring then the one you see on the picture thank you
   / Can anyone tell me what conversion fitting would fit my current valve from this site #7
No, that is the one, did you replace it?
And you never answered in the other thread, were is it leaking, there are three possibilities.
Tightly wrap a rag around the fitting and see were it gets wet first.
attachment.php
good day I thought it was clear on my picture sorry about that its leaking at number 2
Good day all. just a quick FYI I found the 2 conversion fitting for my spool valve and works great the in put and out put size is 15MDL-8MJ / Metric Conversion Male DIN 24* Cone Light Series to Male JIC 37* Flare Thread {1}: M22 x 1.5 Thread {2}: 3/4"-16 ( $32.00 each )
I ordered the 4 others for future use is I get a leak.
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
LMC LOT IDENTIFIER 8 (A53084)
LMC LOT IDENTIFIER...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
UNUSED X-STAR PORTABLE 300 GAL FUEL TANK (A51247)
UNUSED X-STAR...
