Is there a TYM that matches the mahindra 4110
   / Is there a TYM that matches the mahindra 4110 #1
coffeeman
I ordered some parts for my 4110 for my Mahindra. Mahindra dealer PTO gears came with TYM marking on
box. If, in fact, I am thinking right, would it be cheaper to order from TYM or Mahindra for parts?
Cheers....Coffeeman
   / Is there a TYM that matches the mahindra 4110 #2
Perhaps close, but not exact. The 4010 is made by TYM but to Mahindra's specs and with a Mahindra engine. I'd imagine you would need to search it out by specific part numbers for whatever you are seeking.
   / Is there a TYM that matches the mahindra 4110 #3
I thought it has a Daedong (Kioti) engine. How old is the 4010. It could be compare able to the TYM T-450 or if newer the T-433/503.
Yes, it is Daedong engine. Model # is 4110. Owners manual is for 3510 and 4110 with new sheet metal. Horse power, 35 & 41 of course .
   / Is there a TYM that matches the mahindra 4110 #5
Possibly similar to the T350 maybe instead of the 40-50 hp ones I mentioned before. I would ask a dealer. But u might have better luck with mahindra with parts.
   / Is there a TYM that matches the mahindra 4110 #6
After looking at tractor data, the 4110 weighs in around the same weight as the T450 so my guess would be the T450 would be the one. Good luck.
   / Is there a TYM that matches the mahindra 4110 #7
The T400 and T450 will be your closest match for the tractor chassis. TYM used a Kubota and Mahindra used a Daedong which is the biggest difference between the two.
2020 Mitsubishi Fuso FEC7TS Cab and Chassis Truck, VIN # 4UZBVH115LGLFU342 (A51572)
2020 Mitsubishi...
2024 Scag V Ride XL (A51573)
2024 Scag V Ride...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2019 CATERPILLAR 330GC LONG REACH EXCAVATOR (A51246)
2019 CATERPILLAR...
