Kubota 8560 Seat & Tires
   / Kubota 8560 Seat & Tires #1
LS248
Member
Chester, NH
Kubota M6060 & BX1870
i have a couple of questions. I am looking to buy an 8560. While sitting in the seat yesterday at the dealership, I noticed the headrest interfered with my line of vision while hooking up a rear attachment. Didn't think about it until I got home. Is there a way that headrest can be removed from the seat? Also wondering if I can get away with industrial tires instead of Ag tires to pull an 8' snowblower. Any help would be appreciated.
Thank you.
Dennis
   / Kubota 8560 Seat & Tires #2
Boy, an 8560 is a good sized machine to get r-4's on. Is there any other tasks you are going to use this machine for?
i have a couple of questions. I am looking to buy an 8560. While sitting in the seat yesterday at the dealership, I noticed the headrest interfered with my line of vision while hooking up a rear attachment. Didn't think about it until I got home. Is there a way that headrest can be removed from the seat? Also wondering if I can get away with industrial tires instead of Ag tires to pull an 8' snowblower. Any help would be appreciated. Thank you. Dennis
The machine will be used for snow removal, wood chipping, and maintaining food plots. I could probably get away with a 7060, but the price difference between a 7060 and an 8560 is not that much, and the 8560 has a heavier loader. We had 120 inches of snow in a month this past winter and my 3240 was nearly overwhelmed. I am afraid that the Ag tires might ruin my lawn, however. That is why I am asking about the Industrial tires.
   / Kubota 8560 Seat & Tires #5
Hakapelita make a tractor tire that is specific for snow applications. Seen them on a few commercial machines locally and on some municipal equipment used in snow clearing.They look very similar to turf.
   / Kubota 8560 Seat & Tires #6
I used r-4s on my 2620 and have them on my 3350 and have no problems in snow or the woods. The r-4 is muck stronger than the others especially for loader work. I haven't suffered any lawn damage with them except when it's wet and I am in 4wd.
   / Kubota 8560 Seat & Tires #7
An 8560 is going to ruin the lawn. Ag's will only do more damage, your best bet is to put in a dedicated path for the machine to traverse the yard if your getting a machine that size. AS for the snow removal and food plot duties, unless you are using a snow blower and a roto-tiller, you are going to want traction. What size/type of implements are you planning on using? R-4's are great for loader work/puncture resistance/wear, not so much for higher draft loads though some make do. I have a similar sized machine and I'm hunting for traction at times. I have added beet juice(1600lb) to the rears and cast weights(200lb). There are times I would like some more weight to help keep the rear end planted during loader work and that's after I have hung a 1700lb counter weight off the rear end. My machine also outweighs the kubota by more than a couple lbs to start with.
   / Kubota 8560 Seat & Tires #8
As TripleR stated, I have an 8540 with industrial tires. The reason I chose industrial is for their weight rating (I do a lot of heavy loader work which exceeds the capacity of AGs) and their overall tuffness. I routinely work in a retired pasture that I am clearing out those nasty trees with thorns (locust I believe).
In any case, R4s were the right choice for me.
In 2wd, my 8540 doesn't hurt the lawn/yard much. Even in 4wd, if you don't turn too sharp it doesn't really damage things too bad. My area is mostly hard clay, so if you don't drive when it is wet you don't leave much of an indent. I am basically country living with a nice fertilized/treated yard. Not a yard I worry too much about, but I do take care of it. (I say this to try and paint you a picture of my situation.)
As far as R4s and your snowblower. I have an 800' gravel driveway that I clear once maybe twice a year from snow. I only clear it if it gets so deep my wife's awd Edge can't get through it. Since I don't have a blade or any other snow clearing device, I simply use my bucket curled all the way back an brute-force push the snow. This is not very elegant, however it works. (I also do minimum damage to the underlying gravel.) Towards the end of the drive, where it goes up a short steep hill, I have trouble getting up and have to move more snow out of the way. My point is, the R4s do OK in the snow, but if you want to plow through some deep stuff, you may have some problems. In 8" or so of snow, I can't get up my hill in 4wd without clearing a little path and taking a faster run.
I have never used a rear-mounted snowblower, so I don't know how well that would work with R4s. I assume you would be driving through deep snow since the snowblower is on the back. Depending on how deep you get, you may or may not have a problem.
For me, the pros of R4s far outweighed the cons. Everyone's situation is different.
   / Kubota 8560 Seat & Tires #9
The big difference will be what you mean by "lawn". My lawn (I call it a yard) is only slightly marked when my neighbor drives over it with a 1086 international, baler, and hay wagon.
   / Kubota 8560 Seat & Tires #10
As far as the headrest goes...I assume you are looking at the cab'd model. The headrest in my 9540 pulls right off. Unless they have changed the seats on the 60 series, shouldn't be a problem.
INOP/NON-RUNNING 1999 International F-2574 Fuel Lube Truck, VIN # 1HTGGATT4XH682675 (A51572)
INOP/NON-RUNNING...
New Holland C238 Compact Track Loader Skid Steer (A52377)
New Holland C238...
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
