5' Grain Drill for 6' Tractor?
   / 5' Grain Drill for 6' Tractor? #1
Stickbo
Lake Mills, WI
2008 Kubota MX5100
I am going to take a look at an old grain drill that is 5' wide. But my tractor is 6'. I would be running over a bit of previously planted strips on every pass and the drill won't quite cover my tracks behind me.
I like the idea of the smaller drill for ease of transporting on a trailer, but not sure how that would work out for me. Should I pass on this one and keep looking for a little wider drill?
   / 5' Grain Drill for 6' Tractor? #2
You can transport a grain drill up to 8 ft wide on a hitch or on a trailer without getting into trouble with the law. I'd find one at least 6 ft wide--7 or 8 ft is better.
I restored two Minneapolis Moline P3-6 grain drills (10 ft wide, 20 drops, single disc openers) that I bought for $275.
It's relatively easy to reduce the width of a drill like this to 7 or 8 ft.
Good luck
Thinking about it, I suppose I could just pull the drill with my ATV. I think it would handle a drill that size. I'll be interested to see what kind of shape it is in.
   / 5' Grain Drill for 6' Tractor? #4
Actually you will see better germination in the tracks of the planted ground .
   / 5' Grain Drill for 6' Tractor? #5
Yep, going back to the old cultipacker days. :)
   / 5' Grain Drill for 6' Tractor? #6
Offset the drawbar so that the planter covers one side or the other.
The drill was in good shape for its age and everything works. At $700, I couldn't pass it up, and will easily pull behind my ATV.
   / 5' Grain Drill for 6' Tractor? #8
The drill was in good shape for its age and evening works. At $700, I couldn't pass it up, and will easily pull behind my ATV.
There you are--problem solved.
Good luck.
2014 Jacobsen AR3 Commercial Mower (A50322)
2014 Jacobsen AR3...
New Hydraulic Oil Tank With Site Gauge and Filter (A47384)
New Hydraulic Oil...
Wolverine Quick Attach 72" Bucket (A50514)
Wolverine Quick...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
(INOP) KUBOTA RTV1140 CREW CAB ATV (A51243)
(INOP) KUBOTA...
2004 Mustang Deluxe Convertible (A50324)
2004 Mustang...
