Ventrac 4231 Sickle Bar
   / Ventrac 4231 Sickle Bar
:rolleyes: :eek: I don't believe I'll try that !
Just run the duals...it should float lol...I had our old Steiner in about 2 feet of water once...with duals it didn't float but it felt like it was about too....
The overflow is a 30" down pipe 16' long standing on end - It has 1/2' rebar welded on top in a 6" opening grid. I would need to find a way to raise that pipe a foot and then the level would flow out the end of the dam where there is an emergency bypass (so the dam does not get washed away if the 30" pipe will not handle the flow.
I think it would be easier to take a foot off the top of the dam. I need to find someone who has an 8' sickle bar on a CUT.
Nice rig! Try raising the water level!:)
   / Ventrac 4231 Sickle Bar #13
I don't know what year it was made, but I've been teased with those at Ventrac telling me that they were thinking about doing one again. I understand that Ventrac had it made for them by another company and did not make it themselves. I think they could sell a unit like this (especially if they offered it in 6' - 7' - & maybe 8' options.)
I believe it was modified from this unit to fit the Ventrac and Steiner mounting system. - Gaspardo G19502181 09/2006 I found a manual that could be downloaded.
Thats awesome! What year did they make that?
   / Ventrac 4231 Sickle Bar #15
I was just kidding,besides I was afraid to go any deeper with the steiner,as the water was starting to hit the flywheel/ fan on the Onan engine!
   / Ventrac 4231 Sickle Bar #16
Will this work up along a steep bank 30 + degrees down at the same?
Yes, if you can find one somewhere for sale ! :thumbsup:
   / Ventrac 4231 Sickle Bar #18
Do you have any ideas where to start looking ? I don't think Ventrac ever made one. I see you can find Haban that are belt driven, maybe they could be modified to fit the Steiner front mount and use a hyd. cylinder to raise and lower the bar.
I don't have a clue where you might find one - Ventrac did not make this one, but had it made for them. One of the Steiner Brothers (was on this forum as "Ventrac") found it and sent me an email about it. There is still a "Ventrac" on this forum, but I believe it is someone who took over for Dustin when he left on a missionary trip. You might get lucky if you search for{ Ventrac / Steiner Sickle Bar mower } ?? Good luck finding one - I like mine !
   / Ventrac 4231 Sickle Bar #20
I almost bought hydraulic broom for my Steiner. The broom was whipped but I really only wanted the hydraulic pump and tank. That could have opened some custom attachment possibilites including a hydraulic sickle bar mower head I found on the net.
In general, for cutting around our pond, I have not decided if using a sickle bar or big trimmer style cutter would work best.
2017 Caterpillar D6T LGP Crawler Tractor Dozer (A55787)
2017 Caterpillar...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
Portable Restroom (A54865)
Portable Restroom...
