Ford 4610SU Clutch Adjustment
   / Ford 4610SU Clutch Adjustment #1
ETD66SS
Newfane, New York
I bought a 4610SU a few years back. It has been very hard to get into gear without grinding the gears, there was a nail used as a clevis pin on the linkage, I figured the sloppiness in that connection was causing the issue. I replaced the nail with a proper size clevis pin, but it is still impossible to put the tractor in gear without grinding.
Is there some type of clutch adjustment other that taking up all the slop in the linkage? Is this adjustment internal?
   / Ford 4610SU Clutch Adjustment #2
Other than the clevis slop, there pedal should be adjusted via this clevis so that there is approximately 1 to 1.25" of pedal freeplay. If it still grinds after adjusting, then it needs a new clutch.
I think I have already adjusted the freeplay properly, so new clutch it is I guess.
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
LOT LOCATIONS (A52141)
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
71059 (A49346)
71059 (A49346)
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
