Water line easement -- why?
   / Water line easement -- why? #11
There are a couple of attitudes you can have. I work for a civil engineering firm and have written hundreds of easements over the years but have rarely been the one to get them signed. It can be tough.
1. First attitude. Whats in it for me? If there is nothing in it for me, why should I give it? Nothing wrong with this attitude at all.
2. Second attitude. This is probably a non profit public utility. They aren't really looking to make any money off the easement, its just the easy way to where they want to go, and you are saving them money to give them easement. If the easement is where it doesn't impact your ground, it probably won't hurt anything. On the other hand, if its in a location that might hurt your property value, such as a place a house might go someday, you should be compensated.
   / Water line easement -- why? #12
I'd be concerned that once they run an easement through, they can come back and run more utilities through the same easement. That's what's going on around here with petroleum pipelines. They just keep making the easements wider. Its a huge mess for the landowners.
Another thing you may be concerned about is their ability to annex you into a town or city. For example, they run water through an area and put conditions on your property zoning stating that if your well ever fails, you cannot dig a new one and have to connect to municipal water. That happens around here fairly often as well. And they put in stipulations that you won't fight annexation if it happens once you're connected to municipal utilities.
On the plus side, it may bring you good water if your's is questionable, it may bring fire hydrants to rural areas, another good thing. So, be careful what you sign. Pluses and minuses in every agreement.
We already have water from the road on the other side of the property. And there are no fire hydrants out here either although this line would be big enough to support them. I don't think annexation is anywhere on the radar, this 3 miles long road only has five homes on the entire road.
Thanks all for your input and experiences.
Ken
   / Water line easement -- why? #14
One person I knew granted an easement for a large line and only asked one thing... a dedicated fire hydrant and he got it...
At least his insurance rate went down...
   / Water line easement -- why? #15
You say you have water by your house and this is on the back side of your property. Do you have water piped back there currently? Would you like to? If not I would consider letting them do it and putting a connection back there for you to use if you needed it. My land is narrow and about a half mile long. I wish I had water way in the back.
   / Water line easement -- why? #16
The problem here, bdog, is that if a 'town' water & sewage line (the two sort of go hand-in-hand) are put in = you're property tax goes up... whether you've hooked up or not.
AND you have to pay to hook up.
I'd always wondered (up 'til I retired here to a rural setting) why most of the farm houses were so close to the road instead of set back where it was more peaceful. Now I know, it was too expensive to hook up to the utilities.
   / Water line easement -- why? #17
Some of the biggest problems I've had have taken place after people maintained right of ways or "is it rights of way". The less people on my property the better.
   / Water line easement -- why? #18
Very common for local municipalities here to give you X water taps or some other compensation, and those taps can go in your bank for future use whenever/wherever you want them. That's worth money if you plan to build or your kids will build on your property or any other in the same municipality.
I know the rural water hook-up at my property is $2,500 for a water tap, which is why I haven't done it yet. I'll only pay for that if I ever build there. It's keeping me from doing my garden there, which is too bad, because that soil is great.
   / Water line easement -- why? #19
I won't willingly agree to any easement through my property, period. I don't care if would benefit me some how. No easements. Talking from experience.
   / Water line easement -- why? #20
I think a lot of people worries are unfounded.
Why would your taxes go up? If you have public utilities, they might go up slightly because it would add a little value but you already have water.
The easement can be made exclusive. That means its for the water company and no one else.
Annex you? Some cities will require an annexation aggrement to hook up to their utilities. If other people annex and your property then touches the city limits, you are annexed. That doesn't sound like an issue here, its a rural water system.
It sounds to me like the water company would have very little reason to use the easement again unless there was a water main break.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
INOP/NON-RUNNING Hyster Forklift (A51573)
INOP/NON-RUNNING...
2011 FORD F-450 (A52472)
2011 FORD F-450...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
