tc35d no power after heating glow plug
   / tc35d no power after heating glow plug #1
tonyiver
Hello, need some help, I have power when I am heating up the glow plug but once I turn the key to start the tractor I hear a click and i lose all power. after a while it resets itself and it do it again and the samething happens again. check the battery voltage and I get about 12.4 volts. sounds like a relay tripping. where are the relays located? I have the same thing happen in the winter and found out it was a bad battery. the battery is oly a couple years old and I alway take the battery out for the winter. thanks for any help.
Tony,
   / tc35d no power after heating glow plug #2
You need to do a load test on battery. I use a carnon pyle tester myself, but just take battery to napa or likewise and have it tested. 12.4 means nothing.
Another good trst is to have someone hold a tester to battery while you try turning it over.
Thanks for the input, I will be getting my dads load tester. I have had the same problem with this Oem battery, it does not say new holland like the original, I asked the dealer and they said that is what they are putting in as a replacement, this is the second one I've had.
Tony
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2020 INTERNATIONAL...
FRONTIER GM1060E LOT NUMBER 249 (A53084)
FRONTIER GM1060E...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
