Home-made mini tractor 4*4 with the joint joined frame
   / Home-made mini tractor 4*4 with the joint joined frame #111
Hey, this thread is nice also because of that, that people from so many different places can write and understand each other's languages. :)
And in Ukrainian
Гей, ця тема добре також через те, що люди з багатьох різних місцях може писати і розуміти мови один одного. :thumbsup:
In my place it is the same. When I disk I have to periodically stop and clean it otherwise it looks rather like a roller:laughing: That stuff stick to any tools.
And here is my attempt to write in Russian. I use Google translator but then I edit the text so it actually makes sense.
На моем месте это тоже самое. На пример когда я диск мне надо периодически остановить и очистить его в противном случае это выглядит скорее как ролик. Этот материал (когда влажный) придерживаться каких-либо инструментов.
Я работал два года в Росии на постройке газопровода почти 36 лет тому назад и там я приучился Руский язык.
I am impressed by your craftsmanship and ingenuity. You motivate me.
thank you very much!
And in Ukrainian
So, thanks Google
   / Home-made mini tractor 4*4 with the joint joined frame #114
Great work all round Vladimir! Not only very creative and skilled but a wonderful passion for what you do. Just subscribed to your Youtube channel to make sure I get the latest.
Thanks for that subscribed to a channel will share all what I can
hilling potatoes. Cultivator Discs
Hilling potatoes after watering
You have a very good soil for potatoes.
It is not so, hard ground and often have to loosen. One part where growing green manure, more or less light and the second part of hard.
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
2015 Audi A4 Sedan (A56859)
2015 Audi A4 Sedan...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
Hays LT-1 Tender (A56435)
Hays LT-1 Tender...
