ZD21 drive wheel lockup
   / ZD21 drive wheel lockup #1
mchild
Member
The left drive wheel locks up when I move the control level from the forward position back to the neutral position. It has just started this. It seems to act as if the lever has been pulled past the neutral position into the reverse position and the tire is trying to instantly change rotation direction. But, the lever is not going past the neutral position. If I move the lever slowly back to the neutral position I can keep the wheel from lockup. There is no unusual noise or operation and I can drive the wheel in reverse without issue. The right drive wheel has no operational issues.
Anyone have a thought as to the cause? Thanks in advance for your thoughts.
   / ZD21 drive wheel lockup #2
i have a 2001 ZD21 60" with 950 hrs. Last 2 yrs, I have had the brake problems that had to be dealt with at the start of mowing season. On one side or the other, one brake would bind and not go as fast as the other side. apparently rust would set in during the winter storage. This year I replaced the brakes and it is working perfectly this season. It could be a brake issue. Love that ZD21!
Thanks for your response. I have already confirmed it is not the brakes causing it to lock up.
2021 Billy Goat F902H Walk-Behind Debris Blower (A55851)
2021 Billy Goat...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2016 PETERBILT 579 (A53843)
2016 PETERBILT 579...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2012 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56138)
2012 FREIGHTLINER...
