Gear oil capacity for Bush Hog SQ600?
   / Gear oil capacity for Bush Hog SQ600? #1
2dawoodz
I can not find an online manual for the SQ600. I changed the gear oil and added 2 quarts of 80w90. The oil level is approximately 1.5" from the check hole. Is this sufficient amount?
   / Gear oil capacity for Bush Hog SQ600? #2
Google SQ600. You will find them.
Sent from my iPad using TractorByNet
I have. The only owners manual I could locate was for models SQ142, SQ148, SQ160, SQ172, SQ184, SQ84T. The SQ160 has the same overall measurements so I went with the same 2 quart capacity.
   / Gear oil capacity for Bush Hog SQ600? #4
You should be fine. Most lesser brands that use a universal gearbox use a little less than 2 quarts.
New/Unused AGROTK YC-26G Sawmill (A54865)
New/Unused AGROTK...
1999 MACK RD688S MIXER TRUCK (A55745)
1999 MACK RD688S...
2017 FORD F250 SUPER DUTY EXT CAB SERVICE TRUCK (A55745)
2017 FORD F250...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
Frontier FM2015 (A53314)
Frontier FM2015...
