Pilot bearing removal question
   / Pilot bearing removal question #22
Forget all idies ... wet newspaper in that hole ........12mm bolt an hit it with a hammer ........refill the hole ......12mm bolt .....hit it with a hammer .......refill the hole .......you get my idie ? In 35 years that is/was that I do with them !
   / Pilot bearing removal question #23
That doesnt tell me its a ball bearing. Best if info is stated up front.
Google "6001z". If you were familiar with bearing at all you wouldn't need to to know it was a ball bearing.
Sucks not to have the tools you need. The wet newspaper idea might work. I had never heard of that one.
Kim
   / Pilot bearing removal question #24
Kim
The bearing type is critical info ... its # is immaterial. Why should I have to look it up? and then assume it is unique. Good definitive info up front is due diligence. Lacking that, a simple yes or no to a clarifying question will let everybody know.
   / Pilot bearing removal question #25
I don't know that tractor at all, but will ask anyway is the bearing mounted in the flywheel or in the crankshaft?
If the bearing is in the flywheel you can unbolt it then simply drive the bearing out, I only suggest this because your having trouble removing it by normal methods.
   / Pilot bearing removal question #26
Lets see. He said it was a pilot BEARING. And then he said it was a 6001z. That is a very common and recognizable ball bearing number. Looked like good info to me.
   / Pilot bearing removal question #27
BEARING is not definitive - especially as applied to pilots. Answers being given were not as well directed toward a ball bearing as they were toward removal of a plain bearing. Hence the question to overtly clarify ... met with response that appears to have an obnoxious element.
   / Pilot bearing removal question #28
<Fletch movie paraphrase quote>
Awe come on guys, it's so simple, maybe you need a refresher course. It's all 6001z bearings these days! :laughing:
Sorry, been away for awhile. Don't want want to stir up bees here. It is a ball bearing found on F/NH 1520 series compacts (including my 1715). I'll send pictures next time I get up to my place (about a week). I think Ill try the wet paper next and if not I'll buy the cheap HF hammer set and see if I can baby it out with those hook attachments. Thanks for all the ideas!
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
Grady-White 17ft...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A52128)
DeeZee Crossover...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
