Drawbar for 1986 John Deere 1050. Part # CH14119.
   / Drawbar for 1986 John Deere 1050. Part # CH14119. #1
epsomdave1
epsom, NH
Ford 1510
Looking for a drawbar. No longer available as original equipment. Nothing on ebay. Could perhaps make one myself but don't know the material, dimensions or tempering. If anyone knows of where to get one or where I might find specs, it would be appreciated.
   / Drawbar for 1986 John Deere 1050. Part # CH14119. #2
Looks like a straight bar with 4 holes per 777parts.net | 404 - Page Cannot Be Found
Do you have the tractor? Tractor Supply has a couple that might fit:
CountyLine® Drawbar, Swinging - Tractor Supply Co.
Tisco Swinging Drawbar, C5NN805A - Tractor Supply Co.
Tisco Swinging Drawbar Kit, SDA6 - Tractor Supply Co.
Aaron Z
I saw that one too, but it didn't match the configuration I was expecting.
Perhaps someone out there knows if there is a cross reference for other drawbars?
   / Drawbar for 1986 John Deere 1050. Part # CH14119. #4
Just measured mine. It's 29" long(total) and 2" wide x 1 1/4" thick
The pin that holds it is 3/4" or a hair less.
Didn't take the ball off,but I would guess the hitch hole is over 1"
Thanks very much. Any reason to suspect it might be hardened? Also, just to be sure, the bar is dead straight with no step and has four holes?
   / Drawbar for 1986 John Deere 1050. Part # CH14119. #6
Yes ,dead straight,4 holes,don't know why it has 2 small holes? Probably just good steel?
I see one on ebay under "Drawbar,Johndeere T29898" that would work.It's too long,but if you used the 3rd hole for the pin,it would be about the right length.
   / Drawbar for 1986 John Deere 1050. Part # CH14119. #7
Many (most?) are hardened.
Aaron Z
Thanks for all of your help. Turns out that the T29898 item number is the same size (except for length) as the CH14119. You would think the John Deere folks would be able to tell me that! And it was a good $70 cheaper than what I had seen for other parts similar.
Cheers!
   / Drawbar for 1986 John Deere 1050. Part # CH14119. #9
I broke one of those on my old Massey 135 when a sloppy pintle ring bound up on the hitch. I seem to remember the break was sharp and crystallized like it was hardened or at least heat treated.
Jim
   / Drawbar for 1986 John Deere 1050. Part # CH14119. #10
Cheers!
This was a while ago but I'm in the same boat. Did you get the larger/cheaper T29898? Did it work on your 1050?
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2013 FORD F450 XL SUPER DUTY BUCKET TRUCK (A51406)
2013 FORD F450 XL...
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
2013 Chrysler Town & Country Van (A55758)
2013 Chrysler Town...
2025 GIYI GY-BK56M 56in Excavator Boom Skid Steer Attachment (A53421)
2025 GIYI GY-BK56M...
UNUSED LANDHONOR RGB-11-72W - 72" ROCK GRAPPLE BKT (A54757)
UNUSED LANDHONOR...
