2012 Case IH Farmall 45a won't start
   / 2012 Case IH Farmall 45a won't start #1
clr ranch
Paris, TX
none yet
Was working just fine all morning and got off to pull the teeth up from my blade. Got back on and now it won't start. I have dash lights and I have 12.9 volts at the battery, but it does nothing.
Seems like it might be the ignition switch but would appreciate any help you might offer.
Thanks!
   / 2012 Case IH Farmall 45a won't start #2
Thanks!
Sounds like a safety switch. Is the pto still on ,tractor in still in gear,wire loose on the seat switch, hydro petal not in neutral zone, or any other safety switch on this tractor ?
Guess it's time to go liking some more. Thanks for the ideas.
   / 2012 Case IH Farmall 45a won't start #4
If you can post a wiring diagram, more suggestions are possible but amaxwell seems to be pointing you in the best direction.
Dave M7040
Good call on the safety switch! After some more looking I found a safety switch under the tractor, which appears to be connected to the brake pedal. One of the wires was pulled out of the switch. I tried to solder it back for a temp fix since my local dealer was closed, but that didn't work out. Then I tried to straight wire the 2 leads together and bypass the switch. That didn't work either, so I guess I'm waiting until Monday to get it running again.
Thanks again for the help. If anyone has a wiring diagram for this tractor, or possibly a source to get a service manual I would sure like to hear about it.
Valvoline Brake Fluid (A53117)
Valvoline Brake...
2019 Kubota SVL 95-2 (A47477)
2019 Kubota SVL...
1985 Ford Ltl9000 Tender Truck (A53473)
1985 Ford Ltl9000...
City of Lakeland (A51691)
City of Lakeland...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2020 BOBCAT T870 SKID STEER (A52705)
2020 BOBCAT T870...
