How to open this up ~ 1/8"?
   / How to open this up ~ 1/8"? #1
square1
Michigan
Ford 1700 4x4 w/ FEL
What would be the best way to straighten the lower member of this trailer tongue? Its 1/2" thick x 2 1/4" wide. I'm afraid if I try prying / wedging against the top, the top will bend up instead of the bottom bending down. I don't have acetylene torches :(
The only plan I can come up with is to run two or three welds across the bottom piece then drive a steel felling wedge between the top & bottom with my sledge hammer.
Hoping more experienced minds here might have a better plan or be able to tell me why mine will or will not work.
   / How to open this up ~ 1/8"? #2
That will work. Make sure you make the welds on the ground side, as it is pictured.
Thanks! Going to have to flip the whole trailer over though, getting better at vertical up, no way I'm attempting overhead or upside down or whatever it's called ;)
   / How to open this up ~ 1/8"? #4
Really if you think about it. There is no difference in doing overhead, and flat welding.
If you can, get comfortable. Hold a close arc length.
Personally I think where people have a hard time with overhead, is the fear of getting burned. Guess what? You're playing with fire, you're going to get burned! :D
   / How to open this up ~ 1/8"? #5
If you are already thinking of arc welding on the tongue. I would first saw a kerf in the piece at the place where you want it to bend, drive your wedge and then weld up the cut. The cut will make the bottom piece weaker than the top so it should make the bottom easier to bend back into line. My two cents.
SimS
   / How to open this up ~ 1/8"? #6
SimS
Now that is an idea I would not have thought of.
Hmmm...it's an old trailer for hauling wood out with the tractor...what the heck, no better place to practice! Probably won't be posting pics though ;)
   / How to open this up ~ 1/8"? #9
Here is an overhead weld I made with 5/32" 6010. Should have taken a little more time when cleaning the slag off:eek:. Now overhead with 6010, is like standing in a shower of sparks.:laughing:
^^^ For the record, you disgust me ;) ^^^
Alright, heading out to get this project in the books!
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
2016 Kubota M5660SUH 56HP 2WD Utility Tractor (A49346)
2016 Kubota...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A48081)
2022 Chevrolet...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
