Tractor or tiller
/ Tractor or tiller #1
kyfho1963
Fernie, B.C.
JD 4210
I own a JD 4210 tractor and run a 673 JD tiller. I have never had issues with either until this season. Went to till a field and although the tines are turning above ground...as soon as it's dropped in under load...the tiller stops rotating completely although tractor maintains 2500 rpm and 540 at the PTO. Adjusted chain deflection and checked fluids. Tractor has 500 hours and I have also replaced PTO shaft. Hopefully someone can point me in the right direction. My dealer says it may be clutch issues but i'm hesitant to believe that at only 500 hours.
/ Tractor or tiller #2
Hook the tractor to another pto equipment and that will be your answer
/ Tractor or tiller
That's the issue. I don't have another piece of equipment to hook on to.
/ Tractor or tiller #4
Can you hook to a neighbors or someone close by to just test it
/ Tractor or tiller #5
Does the tiller have a slip clutch ? Is it slipping?
Does the tiller have a shear pin ? Is it broken ?
/ Tractor or tiller #6
First off, is your PTO shaft (from the tractor to the tiller) spinning when things "stop"?
If so, the problem is NOT your tractor, it is something in the tiller.
If the PTO shaft is spinning and there aren't any odd noises when things stop, I would strongly suspect a broken shear pin or (if applicable) a broken drive chain.
Aaron Z
/ Tractor or tiller #7
Sounds like a pto drive line slip clutch problem to me...
SR
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
ATTENTION PLEASE READ (A64127)
ATTENTION PLEASE...
Farmall Cub Tractor (A62613)
Farmall Cub...
LOAD OUT AND SHIPPING (A65579)
LOAD OUT AND...
2016 Cadillac CTS Sedan (A61574)
2016 Cadillac CTS...
2011 CHEVROLET TAHOE (A63276)
2011 CHEVROLET...
