fuel bowl crack DK35
   / fuel bowl crack DK35 #1
Avondale
Apple Hill, Ont
Kioti DK35 and Kioti NX6010
Hi My 2006 DK35 had a fuel leak, only when running), the plastic fuel bowl has many small cracks. I shut down the engine as soon as I discovered the source and then shut the isolation petcock. Hope to replace today, question is: will the fuel system need purging?
   / fuel bowl crack DK35 #2
I didn't on mine last year when I had the same crack issue. I was told to just make sure the new bowl is filled with fuel before putting it back on, though.
Ok, thanks
   / fuel bowl crack DK35 #4
Don't think so, but if you do, the steps are in the manual and are straight forward.
   / fuel bowl crack DK35 #5
With what you said happened, you won't need to crack the injector lines. Just fill up the fuel bowl with some fuel and mount it. Turn the valve on the mount to air and start. Run it for a few minutes then switch it to run. All should be good as if you were just changing the fuel filter.
   / fuel bowl crack DK35 #6
The old style clear fuel bowls were hard and prone to cracking. (I had 1 or 2 do it myself)
The newer style replacement bowls are white and more flexible and no more problems with cracking.
Thanks for the help. I gathered there was a problem as the shop had spares. I got the parts this afternoon and should be back in the game tomorrow.
   / fuel bowl crack DK35 #8
Did you get the white bowl ?
You don't want the old style clear/yellow bowl, it will just crack again.
Yes, I got a white one. I also noted that my owners manual and my service manual from Kioti does not mention anything about the fuel filter pet-cock having an "air" position, (as mentioned by VictorW in an earlier post). In any event, I will re-assemble after work today and give it a go.
   / fuel bowl crack DK35 #10
From the owners manual on page 5-5 of the operation section
2020 Westfield MKX 100-83 Auger with Swing Hopper (A53472)
2020 Westfield MKX...
2012 Ford F-150 Pickup Truck, VIN # 1FTMF1CMXCFB58514 (A51572)
2012 Ford F-150...
Three Point Hitch Tiller (A51573)
Three Point Hitch...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
