Looking to build secondary bunk silo, need some advise!
   / Looking to build secondary bunk silo, need some advise! #1
gzfrt9
Member
6615 Cab, 5520 4x4 Loader, 5520 Cab 2 wheel, 4400 Compact,
Small cow/calf operation, and I'm looking at putting in a second bunk silo. 24x36. This would be for overflow. We are looking to use bin blocks or some call them mafia blocks. Has anyone built one using blocks. The questions are how high did you go? Did you seal between them? If so, what did you use? How does it store silage?
Any pitfalls or advise?
Any input is welcome.
   / Looking to build secondary bunk silo, need some advise! #2
No help from me but a question or two, no to be mean either.
How can you afford to put up silage for cow/calf?
What part of the world are you in?
Location: Just north of Detroit, very city here. So pastures are small.
Now the how can you afford to: simple. Calfs at over 2.50 a pounds
Thanks
   / Looking to build secondary bunk silo, need some advise! #4
what makes people think it's so expensive to put up silage? We're doing it for a flock of sheep. I find fuel usage is about the same as when we round baled, we aren't as dependant on the sun shining, we have a huge amount of choices on feed mixes when tmr is considered. I consider it better all the way round. We have made some pretty shrewd purchases on used equipment to keep overhead low.
We we're looking at blocks too and only thing I can say would be to hang plastic on the wall to seal air away. Most are doing this with any wall they use.
   / Looking to build secondary bunk silo, need some advise! #5
They are pretty common around here (north of Brighton). Local cement company sells giant interlocking blocks that would make a good bunk storage area (Livingston Concrete). What about a used shipping container ? All you need is something to get a loader bucket in. And, if it were stacked and anchored on end, you could use a conventional blower/loader and an unloader to feed out with. There have been a few ads on Craigslist for various sized shipping containers.
   / Looking to build secondary bunk silo, need some advise! #6
Actually, there are hundreds of 20, 30, and 40' shipping containers for sale in the Detroit metro area. Many sellers offer free delivery. Dimensions are in their CL posts.
Rockinmywaypa, I to keep the cost low, I plant forage sorghum, which allows me to cut it twice. I also use a flail chopper, with 6 knifes, instead of the standard three. This allows me to chop in one pass. The reason for the second bunk is for the two different times we cut.
   / Looking to build secondary bunk silo, need some advise! #8
have you looked into precast walls that are an upside down T shape, have seen them around but not sure how high they pack with a tractor next to them. I'd like to know how an A shape wall would work made out of pipe and covered with 3/4 plywood covered with plastic sheet. never seen this and figure there's a reason if I haven't seen it before.
Last year we went to the science review in OH, we looked at the T's . They were around 1000, without trucking. That portion could be huge, when coming from OH.
The T's are 8 feet width and 12 tall. $1000.
The bunk blocks are 2x2x6 so to make the same size wall (roughly) would take 12 blocks. The cost at $60 per block is $720. That's why I looked at the bunk blocks.
The other thing about bunk blocks are that we could add additional sides or length if we wish to add (a little at a time)
   / Looking to build secondary bunk silo, need some advise! #10
Location: Just north of Detroit, very city here. So pastures are small. Now the how can you afford to: simple. Calfs at over 2.50 a pounds Thanks
Please don't misunderstand me. I know that cattle are really high right now.
I don't even put up my own hay anymore because I couldn't afford the upkeep on equipment.
I do things a lot different than most and I was just asking a question.
   / Looking to build secondary bunk silo, need some advise! #11
I know of a few like you want. Five to six blocks deep. Ag Bag is really popular here. Less spoiled. Shipping containers should have plastic to protect against the juice or they will rust fast. Just remember to control the face as you feed out. Your feed out face is what should determine the size. Too big = excessive spoilage.
   / Looking to build secondary bunk silo, need some advise! #12
Not sure how high you want to go but I would think the bin blocks would work very well. I would put some type of tar or sealant on the inside edge before I set the next one on top.
Height - I would think you could go 12' high but I would put back fill angled away on the outside to 4' below the top of the blocks to keep them from pushing out or tipping.
Are you going to put an end wall in or just two sides?
As far as silage for cow/calf operations my nephews put about 500 acres of corn silage in the bunkers every year for their cow/calf operation. Of course they are feeding the calves until ready for slaughter but the cows get some too. They have been doing it that way for 40 years and is common for cow/calf operations in their area.
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
2017 CATERPILLAR 120M2 MOTORGRADER (A52709)
2017 CATERPILLAR...
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
2018 New Holland C227 Compact Track Loader (A56438)
2018 New Holland...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
