Travel Trailer Questions - thinking of a long trip
   / Travel Trailer Questions - thinking of a long trip #1
DrRod
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
I am thinking of getting a travel trailer and heading south for the winter. I have pulled horse trailers and utility trailers but never a livable trailer. I have a Dodge 1500 Thunder Road with a Hemi so I think I'm ok in the power department. I don't need anything too big -- just a simple unit with kitchen, shower, and bed. I've seen lots of models in the $10k to $16k range and I'd like any and all of your thoughts on this. Some specific questions:
- Most models have lots of beds. I don't need them. Can they come out or are their models with fewer beds and more living room?
- What sort of arrangement have you found satisfactory for TV?
- Are there models that don't try to look like a suburban house inside [like faux wood]?
- Are the water sewer systems reliable?
- What breaks first?
- What are the pitfalls?
Appreciate your thoughts and experiences.
They do look pretty cool. Sort of reminiscent of the Airstream on a smaller scale. Haven't seen them at local dealers but will check further. Thank you.
   / Travel Trailer Questions - thinking of a long trip #4
Rv.net has a lot of great info on RV trailers.
   / Travel Trailer Questions - thinking of a long trip #5
1. The models that have the most beds are usually labeled BH in front of some #'S meaning bunk house model. Model's listed as RK or LRSS
are standard usually a bed and a pull open sofa or table bed.
2. Lap top computer or cable at sites
3. Yes some are called "toy haulers".
4. For the most part yes but I would invest $10 from Wallmart and use a RV pressure valve in front of water hose going into unit.
5. The bed if your spouse is a full fiquered woman ! :laughing: Just kidding my main concern has always been with water leaks from rain.
6. I have saved a ton of $ using my RV'S and had one heck of a fun time , but it's not for everybody.
7. I would not buy an RV me personally without a slide unless it was an "Airstream". I also have had great success with Mobile Suites and Heartland units . Also might wanna invest another $10 in a RV amp/voltage meter . And some different RV pigtails which for different /reduced power from RV sites etc. Just some of my thoughts .
   / Travel Trailer Questions - thinking of a long trip #6
We have a 21' trailer by keystone and LOVE it! You will definitely need a queen sized bed, and slide out if your with someone, a hallway gets pretty cramped.
I would recommend something a bit larger as by the end of a week or so, Wife, dog and I are feeling a bit cramped!
We also got two matched group 27 (larger) batteries to maximize the amp-hours available if we don't have electric.
Water and septic tank lasts a week with two of us....
   / Travel Trailer Questions - thinking of a long trip #7
Its not easy to get access to the details of how they are made. Ones with aluminium framing instead of wood will be resistant to rot. Externally they should have fiberglass siding (Filon). Usually they have a rubber roof. If you park it outside all year, you will be re-sealing the roof and vents annually. Maintenance adds up fast.
I also like the small fiberglass RV's. Some of the newer ones are double wall, whereas the Scamp is single wall. The head liner / lining on the scamp is a PIA the way it is attached. The cabinets in the scamp are riveted to the shell (point loads) whereas the new RV's are moulded directly into the fiberglass inner. The furniture in the Scamps is still chipboard and melamine. Sad that for the money the best available plywood is not used instead.
Depending on where one plans to go (on a regular basis) one should carefully consider whether you want the AC. All of the AC's add a LOT of weight to the roof and long term that is always trouble. The roof almost invariably fails around the AC attachment point, or sags which allows water to pool and eventually penetrate. Sorry to say, I have never seen a roof strong enough for the AC. I removed and donated the AC that was on my Scamp and put a large fan vent in instead. But then I like high altitude camping in CO or spring and fall camping in the higher lattitudes. Not Texas or Florida in summer..... LOL.
   / Travel Trailer Questions - thinking of a long trip #8
If you buy 1 make sure the A/C & blower cycles on and off with a thermostat.. My compressor will cycle off ,but the fan will not .. You have to get up in the middle of the night and turn the unit off ,or freeze..
I don't know of anyone with an rv that hasn't had a roof leak.. Leaks are hard to find ,but usually easy to repair.
Good luck
   / Travel Trailer Questions - thinking of a long trip #9
I also have a 21 foot camper made by Sunliner. My wife and I spend 9 or 10 days 4 or 5 times a year in the camper. not a great amount of room but has full bath and kitchen dining table folds down for an extra person to stay. Camp grounds are notorious for bad power so I suggest a surge arrestor pigtail between power box and camper cord. also 2 batteries for the cold nights so that the heater will operate all night when boondoggled.
   / Travel Trailer Questions - thinking of a long trip #10
Good luck
+1 on this. Our A/C does not have a thermostat. You can "adjust" the temperature, but it's either freeze or sweat.
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
(INOP) CATERPILLAR 416B BACKHOE (A50459)
(INOP) CATERPILLAR...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
