Oops
   / Oops #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
   / Oops #2
I see you are busy planting
   / Oops #3
It looks like the last pass didn't even rut, then this happened.
   / Oops
Yeah, the tall grass completely hid it, I was just happily mowing along and then I was stopped. Had to disconnect the cutter and drag it out with a truck and then pull the tractor out. Usually, it's the tractor pulling the truck out. Oh well, at least it was a Ford truck pulling my Ford (New Holland) tractor out. If it'd been a Chevy or a Dodge, I'd have just had to hide in shame.
   / Oops #5
Like they say.."If you don't get stuck every now and than your not tractoring" ;)
   / Oops #6
I see you found the spring.
   / Oops #7
First time mowing there??
   / Oops
Yeah, first time mowing there. It wasn't a spring, we really don't have them around her, just a still wet spot from the major rains we had last month. I guess the tall grass kept it from drying out.
   / Oops #9
It's that time of the year again. I've had to pull myself out three times this year and I can't count how many close calls I've had that I was able to get out of while destroying the area with ruts. If you're not getting stuck once in awhile, you aren't trying hard enough!!! :)
Eddie
1998 6.5x16 Anderson Utility Trailer (A56859)
1998 6.5x16...
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2014 International Bucket (A55973)
2014 International...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
