Price Check Whats is worth? MF 180
   / Whats is worth? MF 180 #1
RKJeepXJ
NC
LS R4047H
Looking at a Massey 180. Desiel, 3600 original hours, kept under shed so faded but little rust. Problem is needs all 4 tires. Hasn't been cranked in 5+ years. What's it worth? Prices on tractor house are all over the place.
   / Whats is worth? MF 180 #2
Tires can make all the difference at sales since rubber is pricey now. Also how it's equipped , 6 or 12 speed Multi-Power trans, single or dual auxiliary hydraulics, two stage PTO clutch or fully independent hydraulic PTO, wide or narrow front end, does it run? I repair a lot of injection pumps that won't work after setting as little as 6 months due to water/rust in fuel causing internal parts to stick in place..
6 speed, no multi-power
Two stage clutch
Wide front end
Haven't tried to crank it up yet.
Not looking at any of those. Its actually a tractor in the family, just want to pay a fair price for it.
Historical sales (not asking prices) on tractorhouse show anything from 1700-3500, couple of those have loaders, and most look to have at least usable rubber on them. The one I am looking at does not, sidewalls are completely cracked open.
My head says its worth about 2500-3000 dollars, but it needs ~$2k in tires. And since it hasn't run in many years, probably a few other 100 bucks odds and end to get it usable. Am I off base?
   / Whats is worth? MF 180 #6
I would be thinking lower personally - the new tires are over ½ the value, no loader, 6 speed plus the fact it is technically not running. Having it sit that long could be an issue - if you get it running easily that adds to the value but as of right now you need to price it as non running. Figure a nice running one is running $3500-4000 I would be thinking around $1500 and hope their is no major problems.
207277 (A52708)
207277 (A52708)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2022 CATERPILLAR 249D3 SKID STEER (A60429)
2022 CATERPILLAR...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
