Lowering the lawn
   / Lowering the lawn #1
pohorsky
Loomis
to30, sd1643
We have a 30,000 square ft. lawn surround and divided by a concrete path. The lawn is about 2 inches higher than the cement so every time it rains, the pathways get submerged and muddy. What would you use to remove 2 inches of dirt? I've thought about a scraper, but maybe there is something better.
   / Lowering the lawn #2
a sod cutter
remove the sod, (sell it) then plant a new lawn from seed.
   / Lowering the lawn #3
A lot of how you can do it is going to depend on the top soil depth. If you can take 2" out then replant or replace the sod and still have good top soil? If I was doing it I would use one of these, going forward it will allow you to take small amount off and push into pile.
I would take the top soil off push it into a pile then go in take the clay out put the top soil back. If I had good grass, there I would rent the sod cutter roll it up then unroll it and put it back.
However, depending on how much concrete I had I would look long and hard about either raising it. Putting in drain tile, or putting in a ditch. What I just outlined above is a lot of work.
   / Lowering the lawn #4
a sod cutter
If it were me:
1.Mow the lawn at a two inch height first
2. collect all the clippings.
3. rent a lawn de-thatcher making sure you de-thatch the lawn
at 90 degree angles and then collect the thatch-you are not done
until you have removed all the thatch.
4. rent a lawn aerator and aerate the lawn at 90 degree angles
a. spread gypsum on the cleaned lawn surface to dissolve the clay
5. plant more GOOD grass seed if desired
6. Be sure to weed whack the edges on all the side walks on both
sides as the grass will have a heavy mat of grass growing over
the sides of the sidewalks.
7. decide if you want to rent a lawn edger to clean the grass
away from the sidewalks edges.
It will cost you much less to do it this way than excavate the old sod
and install new sod as you will still have the same problems if you do not do the above.
Short of that you can contract with a house jacker and pump sand under the sidewalk to
raise it above the sod. BUT if the sidewalks were done poorly...........................................
More than anything you drainage pipe and hopefully you have a grade to drain the water away AFTER
you do the work.
I would sacrifice some sod, rent a ditch witch and have a contractor install drainage piping.
BUT if your lawn is in poor condition I would dethatch, aerate it, spread gypsum, plant good seed
and then finish it with a light roller.
   / Lowering the lawn
If it were me:
you do the work.
A couple of things I should have mentioned. The grass is very poor and also very dry. The dirt level is what is high. From what I've been told the cement was there first, and then they filled the area with dirt. We would probably start with new seed. We might put drainage in, but with lowering the soil level the problem will still remain.
   / Lowering the lawn #6
Wouldn't it be a whole lot easier to just add 2" to the top of the concrete?? There are several fairly simple ways to do that.
   / Lowering the lawn
That's at least 1800 square feet of concrete, maybe more.
   / Lowering the lawn #9
If the walkways are cracked, in sections... you could raise them with a layer of sand. I have moved sections before years ago... Back before I had a FEL with a set of forks.. and more time than sense.. :)
   / Lowering the lawn #10
I'd probably dig a ditch on each side of the walkway and lower it by a few inches below the sidewalk level. Then fill back in with gravel or river rock, or regrade the dirt and put down some grass seed. No way I'd be thinking about lowering a large area of the lawn just to keep the sidewalk clean. Just leave the lawn be and make ditches so that the sidewalk isn't the lowest point.
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
CUTTING TORCH (A53843)
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
2012 Ford F-550 4x4 Chipper Truck (A52377)
2012 Ford F-550...
2019 FORD F-350 BUCKET TRUCK (A53843)
2019 FORD F-350...
2015 KENWORTH T800 HOT OIL UNIT (A53843)
2015 KENWORTH T800...
