2 or 3ft wide Bucket for 400 / 500 JD FEL
   / 2 or 3ft wide Bucket for 400 / 500 JD FEL #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
Does anybody make one of these ?
I've seen ripping buckets for Skid Steers.
I'm wanting to dig a drainage ditch between my Two barns.
My 6,7 & 8ft buckets are too Wide :-(
   / 2 or 3ft wide Bucket for 400 / 500 JD FEL #2
The only standard bucket that comes to mind is one for a Terex PT30, but it's 48" wide. What about renting a stump bucket for the day?
If you have 1.5 times your tractor width available between the barns, I'd use a box blade or angle blade. Make an extra deep cut with the first pass and then hit the other side using the fluffed dirt to form the swale. The second cut will move the actual location of the swale back to the other side. Then roll it in to compact.
The only standard bucket that comes to mind is one for a Terex PT30, but it's 48" wide ...
I went to JD dealer today & seen a BW14144 48" bucket that fits 200/300 & 400 loaders.
   / 2 or 3ft wide Bucket for 400 / 500 JD FEL #4
can't use a box blade?
Ditch needs to be 2-3ft deep & narrower than tractor width.
It's filled in with topsoil thru the years so its fairly soft dirt.
Walking Floor Trailer (A50322)
Walking Floor...
2007 CATERPILLAR 257B SKID STEER (A51242)
2007 CATERPILLAR...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
Gravelly Pro-Turn 148 48in Zero Turn Mower (A48082)
Gravelly Pro-Turn...
BROCE BROOM RCT350 SWEEPER (A51242)
BROCE BROOM RCT350...
VOLVO L45G WHEEL LOADER (A51242)
VOLVO L45G WHEEL...
