Maxxis M8008 trailer tire??
   / Maxxis M8008 trailer tire?? #1
coobie
Super Member
S.Michigan
Kubota RTV 1100c, JD 740,Kioti DK 40 with KL401 loader .
Time for new trailer tires.Looking real hard at buying Maxxis M8008 ST 235/80/r16 load range E for my 20 ft PJ trailer 14,000 lbs.Any input from anyone who has run this tire on your trailers?The good bad & ugly?I only use my trailer about 8-10 times per year my max loads are 8,000-10,000 lbs.Local discount tire center quoted me $410 for all 4 tires mounted.Does that price sound fair?Thanks.
   / Maxxis M8008 trailer tire?? #2
Sounds good to me. I got a quote on GreenBall that same size from Costco about a year ago and I think they were around $135 each mounted.
   / Maxxis M8008 trailer tire?? #3
want some good reading go to woodalls rv forum and search st verses lt tires for your trailer . I run LT tires on my trailers with 16 inch rims , higher weight capacity , higher speed ratings . They say maxxis is a good tire , but its still speed limited to 65 mph maximum I believe .
   / Maxxis M8008 trailer tire?? #4
Sounds good to me. Maxxis and Greenball are by far the best trailer tires.
Just make sure they are radials, the install metal high pressure valve stems, and insist they balance them.
Chris
Chris
The quote does include all of the above,Radials,metal HP stems and balance.
Bought the maxxis radials we will see how they hold up.
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
2017 MAHINDRA MAX26XL TRACTOR (A51243)
2017 MAHINDRA...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
