JD 400 Backhoe/Loader won't slow to an idle or stop the engine.
   / JD 400 Backhoe/Loader won't slow to an idle or stop the engine. #1
veewee
Victoria Australia
JD 400 backhoe
My first ever thread! My JD 400 has a CAV distributor type injector pump which I dismantled because of a lack of power, as it had sat for some time in the past with water in it, but still ran. When apart (and this is a simple job, contrary to what I was led to believe] I found that the governor weights were binding with rust in their frame and also the pumping and distributing rotor shoes and rollers were locked above the plungers and the rollers had worn a flat spot. I purchased a new shoe and roller kit and cleaned up all the rust and corrosion with a new seal and gasket kit and re-assembled without altering the mixture setting, but now it starts OK but goes to maximum revs and won't slow down or shut off, so I stop it by blocking the air intake.
I've taken the top cover off and relocated the governor spring one hole tighter and checked that the shut off bar connects with the metering valve but still no joy. The metering valve is worn in the hydraulic head but previous to dismantling the motor would accelerate and decelerate as expected, just no power(originally low first gear needed to move from rest!). Does any more experienced person out there have any suggestions as to what may be my problem, as I'd be most grateful for any clues?
   / JD 400 Backhoe/Loader won't slow to an idle or stop the engine. #2
My suggestion,....get a rebuilt pump , runaway diesels are scary stuff.
   / JD 400 Backhoe/Loader won't slow to an idle or stop the engine. #3
Evidently it's not as simple as you once thought. It is very important to have the spring under cover attached to correct locations. Sounds to me as if you have a governor problem.
   / JD 400 Backhoe/Loader won't slow to an idle or stop the engine. #4
To me it sounds like you didn't hook up something inside. I would say chances are that the governor is working. There is just some linkage hook up the went unnoticed when you took it apart and now the governor isn't controlling the amount of fuel injected. I would look for a video online and see if someone has been where you are. I'm sure it will be something simple. As a last resort you could take the pump to a diesel shop.
I will also add that you should put the springs inside that you moved back to where they were. The springs aren't the problem.
New/Unused CFG Industrial MX-CRT23 Mini Skid Steer (A54865)
New/Unused CFG...
23311 (A51694)
23311 (A51694)
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2018 FORREST RIVER CRUISE LITE CAMPER (A53843)
2018 FORREST RIVER...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A55301)
Kuhns AE10 Small...
