Which hydraulic valve should I choose?
   / Which hydraulic valve should I choose? #1
Mcrib
Margaritaville
none
I got a different field sprayer that has hydraulic fold booms however it also has a hydraulic cylinder to raise and lower the booms and a hydraulic driven pump. The problem is I only have 2 hydraulic outlets on the tractor that I spray with. Was wondering if I could just put a valve in the system that switches between folding the booms and raising/lowering them using one outlet. I would like it to be electric so I don't have to get out of the tractor just to flip a switch. I have seen valves like this before but I cant remember what they are called, so I figured I'd ask you guys.
   / Which hydraulic valve should I choose? #2
   / Which hydraulic valve should I choose? #4
Does it use a single button switch or a rocker type switch ? I've seen both but am confused when to use each one.
   / Which hydraulic valve should I choose? #5
If you want to lock the valve in a certain position, use an on/off switch.
If you want momentary operation, use a button switch.
   / Which hydraulic valve should I choose? #6
Diverter valves generally use momentary single pushbutton switches especially when used to control grapples and 4n1 buckets. In some applications, a ON/OFF rocker or toggle switch is used, in your case either would be OK.
Other valves use a three position center off switch, but these are directional control solenoid valves, not diverters like your asking about.
   / Which hydraulic valve should I choose? #7
One side of the diverter/selector valve is a default mode with no voltage applied.
Other side is only active when you apply power.
Whichever hyd circuit you use the most should be the default.
   / Which hydraulic valve should I choose? #8
Thanks for the help, now I understand the difference.
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
US 100 hp Electric Centrifugal Pump (A50121)
US 100 hp Electric...
PT Spray Rig (A50121)
CAT 973 (A47384)
CAT 973 (A47384)
2012 New Holland L225 Skidloader (RIDE AND DRIVE) (A50774)
2012 New Holland...
