Moved up to Super UDT2 today in my L3400
   / Moved up to Super UDT2 today in my L3400 #1
vulcancowboy
Gold Member
Duncannon, Pennsylvania
Kubota L3400 HST
I bit the bullet and bought 7.5 gallons of the Super UDT2 ($160) and the filters. It was too rainy to do anything outside so I changed the fluid & filters. Had enough SUDT2 to put it in the front axle too. I'll provide observations if it ever stops raining long enough to put it to work.
   / Moved up to Super UDT2 today in my L3400 #2
Did the same thing yesterday, bought 10 gallons and filters. Not planning on changing mine for a couple of weeks, but also waiting to see the results. Local dealer does not carry it, says it doesn't do much good around here, but does not know anyone local who uses it. I told him I would be the guinea pig.
   / Moved up to Super UDT2 today in my L3400 #3
Where you guys located? I think the sudt2 really shines in cold weather operation. Maybe not notice too much difference in warmer climates. I am a believer in it. I am in pennsylvania. What fluid were you using before? The sudt2 is semi synthetic.
I'm in PA too, near Harrisburg. Not sure what fluid was in my tractor when I bought it, which is t he main reason I changed it, now I know.
   / Moved up to Super UDT2 today in my L3400 #5
I am down in the warmth. Cold here is below freezing. The original fluid in Kubota L-series is Kubota UDT. The SUDT is supposed to suppress the whine and smooth out the hydraulics. Also, when changing the front axle oil fill it and give it a day or so and recheck it, you will find you will have to add up to a quart or more. Then check it again in a week. It takes a while for the fluid to refill the lower bevel gear assembly. FYI, Kubota oil products are made by Vavoline.
   / Moved up to Super UDT2 today in my L3400 #6
SUDT2 definitely helps with the whine. Seems to operate smoother over all.
I have been very happy with the performance since I switched.
Thanks for the tip about re-checking the front axle fluid level!
   / Moved up to Super UDT2 today in my L3400 #8
ok If I am correct Kub has 3 different hyd fluids UDT for warmer climates SUDT older (maybe no longer available) colder clim and replacement SUDT 2 colder and partly synthenic.
   / Moved up to Super UDT2 today in my L3400 #9
Kubota has two fluids. Standard UDT and synthetic SUDT2. SUDT2 replaced SUDT a while back. Either is suitable for all climate operation just like motor oil. SUDT2 just flows better in cold climates, has better wear properties, is supposed to smooth hydraulic operation, is said to reduce whine, and of coarse costs more.
I finally got a chance to run my tractor for about 3 hours today after the change to SUDT2, and I am very pleased. Much less whine :thumbsup:, my whites are whiter and my colors brighter :laughing:. I checked the level in the front axle and ritschner you were right, I added about another quart.
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
JOHN DEERE 648R LOT NUMBER 105 (A53084)
JOHN DEERE 648R...
WESSEX AT110 LOT IDENTIFIER 157 (A53084)
WESSEX AT110 LOT...
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A53472)
2017 Ford F550...
KUBOTA ZG222 ZERO TURN LAWN MOWER (A51247)
KUBOTA ZG222 ZERO...
