Rude Monday Morning Awakening
   / Rude Monday Morning Awakening #1
NoTrespassing
East Central Illinois
Kubota 1999 L3710 HST FWA
I woke up for work this morning and heard what I thought was our water softener regenerating. It's in a walk in closet in our manufactured home along with the well pressure tank. Upon further inspection, I found that the pressure tank had sprung a leak and was spraying water everywhere! I ran outside, shut off the water under the house and turned the power off to the well pump. A trip to Menards and a lot of swearing and we're back to normal now. The tank only lasted about 5 years.
There's no easy way to put a drain under the tank but I did put a pan under it so I can tell more easily when the new one starts to leak in another 5 years. I think the old one had been leaking slowly for awhile.
Kevin
   / Rude Monday Morning Awakening #2
If you had one of the old style tanks that used used air head pressure above the water, then I can relate. Our first tank lasted 3 years and corroded through. The next tank was much smaller, and the water was contained in a bladder. Not 100% sure how it works, but it lasted about 10 years, which with our hard water and earthquakes is pretty good.
   / Rude Monday Morning Awakening #3
Nice work. You can get an electric with battery backup, leaking water sensor. If there is a next time, you'll have some early warning.
   / Rude Monday Morning Awakening #4
You can buy a water sensing alarm for short money. I put one near an enclosed water heater in a MH I used to own.
   / Rude Monday Morning Awakening #6
Isn't Menard's great? You gotta love a place where you can buy a pressure tank, a pair of jeans and a can of beans!! It's my favorite store!
Glad you got it all fixed!!
   / Rude Monday Morning Awakening #7
Of course it was Monday morning. :D
We have one of these WellMate polypropylene reinforced tanks. It's nine years-old now and seems to be holding up.
https://www.freshwatersystems.com/c-35-composite-well-tanks.aspx
I use the same kind. Cost more up front but a lot cheaper in the long run. It's very unlikely it will ever leak. The only way they can fail is when the bladder leaks. I know of some in service for over 20 years.
I was replacing the steel ones in 2-3 years and it's very inconvenient to deal with it during the week.
The last steel one I had is now my air compressor tank
I'll try to remember the composite tanks in about 5 years when my current one fails :-(
2121 (A51244)
2121 (A51244)
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
CHAMPION 3" CHIPPER (A51248)
CHAMPION 3"...
