TNN 55 ignition switch
   / TNN 55 ignition switch #1
aglee
Loudon, TN
TN 55
Installed a new ignition switch on a TN 55 Tractor. The tractor will start, but will not shut off.
   / TNN 55 ignition switch #2
On some machines (including mine) the key doesn't shut it off. Diesels don't have ignitions so if no electric fuel pump or electric injectors or shut down solenoid you use the throttle to turn it off.
:welcome: to TBN
   / TNN 55 ignition switch #3
Sounds like you connected the fuel shutoff solenoid wire to a positive leg on the switch OR the new switch is faulty.
Why did you replace the switch?
   / TNN 55 ignition switch #4
Was the switch OEM or generic?
Generic might not be exactly the same connections, (but 'almost')
The shutoff solenoid would be a normally closed wanting a switched power connection.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1459 (A57192)
1459 (A57192)
Yanmar YT359 (A53317)
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
2007 Pierce Dash Pumper Fire Truck (A55973)
2007 Pierce Dash...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
