JD 5100E vs Case 95C vs Kubota 9960
   / JD 5100E vs Case 95C vs Kubota 9960 #21
I sell the 95C, $53K is a great price.
Look at the 95 or 105U as well. Nicer transmission, heavier, same engine and cab. Probably 5K more.
   / JD 5100E vs Case 95C vs Kubota 9960 #22
I like that 95u! I might go talk to case dealer. Sweet! Puts my e to shame.
   / JD 5100E vs Case 95C vs Kubota 9960 #23
When I was shopping late last fall, the NH T5.95 or T5.105 with cab and FEL was about 10K higher than the equivalent NH T4 models. The T4 and T5 series share the same engine but everything else on the NH T5 series (same tractor as Case Farmall "U" series) is heavier duty. It really comes down to your intended use and for my use the T4 should be adequate. But if I could have spent an additional 5K for a T5 model, I would be sitting in one.
Anyone have experience with a 6115D? Looking at one with a 24x12 trans loaded out. Id like to be able to farm 150 acres row crop eventually.
   / JD 5100E vs Case 95C vs Kubota 9960 #25
Kioti DK90. Good tractor and comparable to the models you listed for less money. Until you mentioned the 6115D....
   / JD 5100E vs Case 95C vs Kubota 9960 #26
The Kioti DK 90 was on my list of potential tractors but it does not have a hydraulic shuttle; a must have for me. The JD 6115D is a much larger and heavier tractor than what I needed but IMO would make a good row crop machine for 150 acres.
   / JD 5100E vs Case 95C vs Kubota 9960 #27
They have a 4.105 looked at in Crockett was nice image.jpg didn't get price but out of the three mentioned I would have to go with that 95c just like the interior over all the rest. That 6115D is in the mid 60's? I looked at the 6105D back when I was tractor shopping but for what I could have got for the price in the Kubota GX series,I would have went with the Kubota. I just ended up finally buying a low hr New Holland TL100 for 50,000 less.
How do you like your TL? I found a 4x4 TL100 with loader for under $30k but didn't know much about them.
   / JD 5100E vs Case 95C vs Kubota 9960 #29
I like it,it does good for me pulling 15ft batwing and RND baler. It's comfortable,rides smooth across the pasture. image.jpg. It's heavy would say around 12,000lbs. Should you be looking for like a TS135a,something in that category?
   / JD 5100E vs Case 95C vs Kubota 9960 #30
I would look at the Kubota MX 100 for a deluxe tractor with the extra weight that you seem to want. We normally look to go to 130lbs per horsepower for optimum performance with tillage. Mixed usage would be 120 lbs per hp and general utility work would be at 110 lbs per horsepower. Different wheel combinations with tires can add 500 lbs or more to a tractor so depending on who sets up the tractor will change the results.
2116FL (A56857)
2116FL (A56857)
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2019 DODGE RAM LARAMIE 5500 FLATBED (A58214)
2019 DODGE RAM...
2009 Dodge Ram 3500 Flatbed Truck with Liftgate (A55973)
2009 Dodge Ram...
2007 CHEVROLET Silverado (A56858)
2007 CHEVROLET...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
