Napa Diesel oil. good enough for compact (ag use) tractors ?
   / Napa Diesel oil. good enough for compact (ag use) tractors ? #1
UncleBuck01
NY
Mahindra 4110
I have used their filters (WIX Made) for years on my tractor, but never their oil. Napa oil is on sale this month $1.99 qt. Rumor has it that it is Valvoline in a Napa bottle ? Would you put this in your tractor ?
   / Napa Diesel oil. good enough for compact (ag use) tractors ? #2
Please buy another Mahindra 4110, replace the oil in your current tractor with this Napa oil and put Shell Rotella in the new one. Run them both hard for 10 or 15 years... then get back to us on whether you found any difference. Thanks!
   / Napa Diesel oil. good enough for compact (ag use) tractors ? #3
Is it CI rated?
   / Napa Diesel oil. good enough for compact (ag use) tractors ? #4
If it meets specs it's fine. My Ex Father In Law worked for Pennzoil then Shell. His old joke for SAE rating was SAE stood for Same As Everyone. He's right. Say Rotella and the Napa oil both meet SAE 15W40 CJ4+ rating they both meet the same mini spec.
Chris
   / Napa Diesel oil. good enough for compact (ag use) tractors ? #5
The NAPA oil on sale for $1.99/quart-limit 12 quarts-is rated SN,gasoline engines only!
It is supplied by Ashland Oil who also markets Valvoline,although it is most likely not the same formula as the white bottle Valvoline.
It's the same "spec"oil sold by AutoValue,Bumper to Bumper,etc.
Perfectly acceptable for your car,please don't use this in your tractor.
Good Luck!
I'll do that just for you. But first you can beam me up "scotty" so we can talk about that bridge I want to sell you :confused2:
Chris
Chris
All Napa oil is on sale including the 15w-40 CJ-4 :thumbsup: Thanks http://www.napaonline.com/Catalog/C...-Viscosity-15W40-CJ-4/_/R-NO_75123_0006411544
   / Napa Diesel oil. good enough for compact (ag use) tractors ? #7
Long as it's rated with the proper rating for your engine.
They just contract out and buy from a major-- probably Exxon, Shell or Mobil -- including additives. Some, like Castrol used to do this, but they'd buy the base oil and put their own additive pack in it. When I worked for Exxon, we sold Castrol a whole bunch of base oil.
Ralph
   / Napa Diesel oil. good enough for compact (ag use) tractors ? #8
Nothing wrong with Napa oil, My truck is about to hit 200,000 miles. 12 years later. No oil consumption of any kind. It is bottled by Ashland oil. Not sure what else to say aside from use it and abuse it. :drink:
Thanks all who gave a helpful reply, BuilderML, your 12 yr use of this oil has pushed me enough to give it a try....... :thumbsup:
   / Napa Diesel oil. good enough for compact (ag use) tractors ? #10
But don't buy the 'S' rated gas oil.. get a 'C' rated oil.
At my the contractor we work for, we have went thru thousands of gallons of napa oils over the last couple decades..
At my home farm, i have used napa, walmart, car quest, tsc, rural king.. every off brand you can find.. coastal.. kendal.. etc..e tc.
I've yet to see anything attributed to a lube failure from heavey equipment to automobiles.
Buy correct spec oil, change on correct usage schedule by miles, usage type or oil anyl.
For severe duty stuff, I spring for better oil, but that's just a couple special cases..
2010 TAKEUCHI TB235 EXCAVATOR (A51246)
2010 TAKEUCHI...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
