PTO seal- Ford 1700
   / PTO seal- Ford 1700 #1
tracboy
oregon
Ford
Hello fellow tractor folks! Im looking for help locating the seal for my PTO. Does anyone know where to purchase this? Also what oil to refill with. Thank you in advance.
   / PTO seal- Ford 1700 #2
I just use regular hydraulic fluid from Tractor Supply (yellow bucket). Try Weavers, Southern Global, and ssbtractor.com
:welcome: to TBN
Thanks for your quick response guy's!
   / PTO seal- Ford 1700 #5
You're welcome. You can also do a search here for a specific thread on Ford 1XXX PTO seal and get more info. I seem to remember someone else doing a PTO seal recently.
   / PTO seal- Ford 1700 #6
messick website easier to goto... vs going to ford/newholland website Document Moved and getting to the parts section.
owners manual / operators manual = most likely what will tell you what type of oils to use along with check list of maintenance that needs to be done for changing oils / filters.
if you can get by with just "parts diagram" see above website links.
shop manual = tearing everything apart and checking things step by step, with much better diagrams. in how to do this or that in fixing / maintaining the tractor.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2006 BOBCAT S130 SKID STEER (A52576)
2006 BOBCAT S130...
2001 Blaw-Knox PF 150 Paving Machine (A52384)
2001 Blaw-Knox PF...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
John Deere 9620R Tractor (A53342)
John Deere 9620R...
2016 Freightliner Tandem Bucket Truck, VIN # 1FVHCYCYXGHHA5025 (A51572)
2016 Freightliner...
