Rims for a 1986 ford 2110
   / Rims for a 1986 ford 2110 #1
mtestagolf
leominster,ma
new holland tc33d
My ford 2110 has calcium loaded tires in the rear. The rear left rim if rusting out and I called the dealer the other day and he gave me a price of 1100.00 for the outer rim, it is a 2 piece rim with 8 loops. Anyone have any suggestions or are there aftermarket companies that sell them. Thanks Mark
   / Rims for a 1986 ford 2110 #2
Unverferth sells rims, but this would be custom OR you can buy a blank rim without the hoops, order the hoops separate and weld them in place.
Also, I may have a rim.
   / Rims for a 1986 ford 2110 #3
Take a look around this site Loop Rims
Blank Rims
Hey Wheel
If they don't have what you need I'm sure they could make it up for a lot less than $1100 and probably less than Unverferth also.
Good luck.
   / Rims for a 1986 ford 2110 #4
Bet it's rotted around the valve. Good tire guy can cut that out and weld in a new section from a similar rim (speaking from experience).
   / Rims for a 1986 ford 2110 #5
Good luck on your issue. I also need to replace/ repair my rear rims for a ford 2110 1987 I believe. Keep me in the loop if you find a deal on rims etc. thanks
   / Rims for a 1986 ford 2110 #7
will look into that. Now will a tire place re install the tire because of the modification and not DOT approved. I heard that I go this rout that some places wont do it because of the welding of new patch.
   / Rims for a 1986 ford 2110 #9
DOT has no authority regarding tractor tires or tractor wheel equipment.
   / Rims for a 1986 ford 2110 #10
I doubt Unverferth sells direct retail. our dealership has direct bolt on rims for this application custom built, as well as a couple other NLA or overly expensive Ford/ NH rims.
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
2001 DITCH WITCH JT1720 DIRECTIONAL DRILL (A51242)
2001 DITCH WITCH...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
