PTO hard to engage and grinding
   / PTO hard to engage and grinding #1
blaze 57
John Deere 870 the PTO is becoming gradually harder to engage. Is there an adjustment?...Does the clutch adjustment rod have something to do with it? Thanks
   / PTO hard to engage and grinding #2
If you have a dual stage clutch, it's probably a clutch adjustment.
Yes Roy, its dual clutch. I did find the nut adjustment on a threaded rod where it goes into the clutch area...I'll try adjusting that. The tractor has over 2,000 hrs and I've never adjusted this area since new in 94' thanks.
   / PTO hard to engage and grinding #4
Follow your manual. Not all adjustments are the same, or done in the same order
2025 Electric Diesel Fuel Pump with Hose Reel (A55852)
2025 Electric...
2021 Club Car Carryall 500 Utility Cart (A55851)
2021 Club Car...
KOMATSU PC138US LC EXCAVATOR (A52707)
KOMATSU PC138US LC...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Yamaha (A55758)
Yamaha (A55758)
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb 2 Ton Mechanics Crane Service Truck (A53422)
2019 Ford F-350...
