kioti grease fittings
   / kioti grease fittings #31
Just to reassure anyone reading this thread about the kioti zerk thread size, chuck172 is right. But I'd like to elaborate a bit. The thread size is 1/8 28 BSPT (British Standard Pipe Thread), A confusion we may run into here is the lack of labeling from manufacturers. They don't always include the "T" in BSPT. The tap, die, or zerk will sometimes just be labeled BSP. Now, BSPT is a tapered thread, like most pipe threads are. Very very similar in size to NPT, but not quite, which is where much of the confusion originates from.
All would be fine if there were only one type of BSP thread. But alas, such is not the case. There is also a BSPP (British Standard Pipe Parallel), that is also sometimes just labelled BSP. This thread is straight, and will not quite fit our application. It is too wide at the beginning of the thread to get it easily started.
Further confusion is added when providers call the thread "BSP straight" which implies BSPP, But sometimes shows up to my shop as BSPT, and other times it shows up as BSPP :confused3:. More confusion still, BSPT male will actually fit into BSPP female, albeit slightly sloppy start of thread. But BSPP will not fit into BSPT.
All of that said, at the end of the day, what we need is 1/8 - 28 BSPT. You can find them on Ebay and a few other places online, but, don't always trust their labeling. Zerks are cheap, though, so order a few kinds if you are unsure.
This thread size is true for my 2014 Kioti DK45HSE, the KL401 loader and the KB2485 backhoe. anyway.
BSPT = British Standard Pipe Tapered.
BSPP = British Standard Pipe Parallel.
Tapered and parallel refer to the thread profile.
   / kioti grease fittings #32
Yes, that is correct
   / kioti grease fittings #35
Thanks to all. Now I just have to find some. I guess Grangier. There is a Grangier 15 miles away
Found them on a website called Zoro for $3.22 +s/h for total of $8.57
Kingfisher Grease Fitting, Str, 1/8-28, PK10 3ANZ2 | Zoro.com
Zoro is Grainger's online discount division established to compete with some of the other online retailers. Their product offerings are much more limited than Grainger itself, but what they do have is cheaper.
   / kioti grease fittings #36
They are a lot cheaper than that from a Kioti dealer.
My dealer said they are on backorder. And I can't believe they'll charge $3.22 for a 10 pack. They don't have anything under $5. I paid $1 each at a local auto parts store but it didn't fit.
   / kioti grease fittings #37
I didn't get that they were 10 for $3.22. My bad. I stock the Kioti part number, and yes, they go on backorder time to time, but I try to keep them on hand.
   / kioti grease fittings #38
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
2013 TAKEUCHI TL10 SKID STEER (A52707)
2013 TAKEUCHI TL10...
2013 Cummins ISL G 300 8.9L 6-cylinder Turbo Diesel Engine (A55851)
2013 Cummins ISL G...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
