Going back to dealer!
   / Going back to dealer! #1
hunt4570
Elite Member
South Carolina
Grand L3540 ,724 loader, bucket, grapple and now forks also! And just for OP.. a pool!
Kubota L3540 HST/L724 FEL
Having loader problems. All works fine except seems like there is no breakout force! I can pick up a bucket full of wet sand (plenty of power), leave it raised for hours with no bleed down to speak of (no internal leaking) , but say I use my grapple to pry a big root out of the ground or something, or try to push or pull the tractor with the bucket curl... seems like I have a dead stick! It doesnt moan and groan like its trying, just nothing. So before I get this thing stuck, with no ability to walk myself out with assistance from the loader, its going to the dealer to see what they can find.
I searched, and posted new about this here and at Orange Tractor Talks, but I'm getting no advice that will work :(, I'll let you know the outcome.
Man I hope they can get it done quick, I hate to lose my tractor!
   / Going back to dealer! #2
Good luck, if disconnecting/reconnecting hose don't do it, I'd sure get the dealer on it, I've gotten out of a lot of messes with the curl/dump function. Out of curiosity, does it act the same with the bucket as grapple? The reason I ask is with my pallet forks, my curl/dump is very weak due to the length of the tines.
   / Going back to dealer! #3
i'd be pulling hte lines to curl / dump to see if they pressurize, er.. or at least flow in correct directions with spool operated.. the hookup to cyl with one end unpinned.
ditto on question about curl/dump working with loader bucket?
Yes, bucket and grapple exactly the same..
The curl/dump works just fine in mid air.. just no power there. Lets say I dump the bucket, then lower to ground and backdrag.. it holds its own, doesnt curl back up or anything.. just no power to pull or pry with it!
   / Going back to dealer! #7
relief valve maybe? would explain why the loader functions with no load, but the minute you try to use it, you get nothing.
Maybe.. I'm pretty mechanically inclined, but hydraulics are pretty much a mystery to me!:confused3:
   / Going back to dealer! #9
Me too! About all I have figure out if that flow relates to speed and pressure relates to strength. So, if something moves, but is weak, it likely pressure related....
   / Going back to dealer! #10
Does curl/ dump have its own relief?
Evidentally the check valves are good and it is cycling oil if the bucket moves under load.
One thought, blown cyl packing.
Leave lift hose in, remove dump hose, pressurize lift, see if oil blows out dump.
Remember dump lift swap depending on spool direction
2018 Infiniti QX60 Multipurpose Vehicle (A51694)
2018 Infiniti QX60...
Case IH 1666 Combine (A50514)
Case IH 1666...
2 pt IH Sickle Bar Mower (A50515)
2 pt IH Sickle Bar...
Bobcat 60" Skidloader Sweeper (A50774)
Bobcat 60"...
2023 Power Skid Steer Loader (A50322)
2023 Power Skid...
