F5720 snowblower for F3080
   / F5720 snowblower for F3080 #11
Thanks Dan.
I am getting a smaller weight that'll bolt onto the existing weight, just like you did. If I'm not happy with it, i can exchange it for the same you have. According to the dealer i wont "need" it, but since i was doing some good negotiating, i figured i might as well have them. They also said, to take the extra weight off for the summer since it's harder on the steering and suspension.
Do you know anyone that has rigged up a trailer hitch?
Hi,
Yes I've seen several commercial guys install a 1-7/8" ball hitch on the back end. This machine is not really designed to pull anything substantial, check the frame section and you'll note that its not too big. I don't see an issue with a few hundred pounds but I wouldn't want to get into too much severe cross country bouncing & crashing...
There are 2 large 1" diameter holes in the counterweight that you could bolt a tow bracket to, should be easy work
If I see a set-up at my local dealer I'll take a picture of it and send it to you Pete
Dan
   / F5720 snowblower for F3080 #12
Hi,
Dan
I just use the hitch for moving trailers to and from the shed upto my driveway when i need one. Nothing major...
Just thought i'd ask. When it arrives tomorrow, i'll be able to see what can be done to rigg something up. But if you happen to see something please post a pic.
Thanks Dan
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
2025 XKH39 39in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 XKH39 39in...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2014 Ford F-250 4x4 Ext. Cab 8ft. Flatbed Truck (A55852)
2014 Ford F-250...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
