Buying Advice BT650 Kubota. Questions can't find info anywhere
   / BT650 Kubota. Questions can't find info anywhere #1
MatLayfield
I found one in good shape for a deal but I have a few quedtions.
Will it fit a B7300HSD
Is it a 3pt or subframe mount.
   / BT650 Kubota. Questions can't find info anywhere #2
BT650 was the backhoe attachment for the B20, a commercial grade TLB based on the B series tractors. The backhoe was frame mounted to the B20. Since the B20 was considerably reinforced over its B tractor cousins, I would be somewhat surprised if there were a bolt-on subframe to mount that backhoe to a standard B. Worth checking out though. That should be a good little backhoe.
NEW Fork Extensions (A53002)
NEW Fork...
Unused 2025 Spirit Mini Golf Cart (A51694)
Unused 2025 Spirit...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A53472)
UNVERFERTH 330 -...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
