Troubleshooting a Robin EH65
   / Troubleshooting a Robin EH65 #1
jurzeyfresh
Newton, NJ
Laymor LB25
My Laymor LB25 has not been running well. Whenever i put load on it it wants to stall. I figured out that for some reason it intermittently stops firing in the cylinder on my left hand side. I pulled the plugs and cleaned them and checked all of the connections and found nothing missing.
I also removed the plastic on the front and found no missing or out of place wires. I cleaned the surface of rotor and checked the gap for the coil and didn't find any issue.
Is there something else i should check before replacing coils that could cause one cylinder to not fire?
Thanks.
Chris
   / Troubleshooting a Robin EH65 #2
Thanks.
Chris
Check your valves. One could have loosened up. That seems to be a fairly common problem on Robin Subarus. You might also want to ask some folks in the PowerTrac forum. Lots of folks with that same engine over there.
http://www.tractorbynet.com/forums/power-trac/
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
HURRICANE 5' X 10' CONTAINER (A51248)
HURRICANE 5' X 10'...
2018 John Deere TX Gator (A50123)
2018 John Deere TX...
ATLAS 10 1/2' DISC HARROW (A51247)
ATLAS 10 1/2' DISC...
