F mower squeaking?
   / F mower squeaking? #11
Dan
Thanks for the reply.
When you mention operators manual, are you refering to the deck or mower manual, and what area in the manual (page number)? I ask only because I had to of miss it.
Common sense tells me to lube, and although I feel like an idiot for asking such a simple question, because I didn't see anything mentioned in writing, why I felt compelled to ask.
I hope I'm not dreaming this up Pete, I've been known to do that from time to time...I'll try to find the statement.... nevertheless "oiling" is something I've done throughout my mechanical career, I consider this as a" mechanical best practices" category. Any equipment I own that has a metal to metal contact points, I apply oil or grease to. This is not only to limit squeaks but reduces metal wear as well. This lube is in addition to the identified grease points that "sandalwood" provided in his message.
Same applies for the end of season storage, I make it a point to wahs everything, paint-up all damaged surfaces and oil spray everything. I realize this might sound overkill to some, but I like all my tools and equipment looking like new.
I also use "crown" on all hydraulic hose fillings. You'll be thankful that you did when it comes time to replace a blown hose. 5 or 10 years down the road.
But, back to the point, I read this oil thing somewhere recently, so I'll try to get the chapter & verse...
Dan
Dan
Thanks Dan.
Myself never being mechanically inclined, I've always relied on instructions when it comes to procedures (I can read and follow instructions, which has helped me in my life).
Thing is, as dumb as I am, it only makes sense to oil metal on metal parts that come into contact with each other. I've never been afraid to ask a stupid question:D
Being that this mower cost more than any vehicle I've bought, I want to make sure LOL
   / F mower squeaking? #13
Thanks Dan for the oiling advice and the use of "crown" on hydraulic fittings. I hadn't thought about the latter.
I'll be pulling the trigger this week on an F2690 either with the Ottawa dealer on his competitor in Winchester. I would have liked a little more power than the F2690, particularly for snow blowing, but that doesn't appear to be possible at the moment, unless one goes with JD.
Both local dealers told me they wouldn't sell the F3990 until the DPF issue is resolved.
   / F mower squeaking? #14
   / F mower squeaking? #15
   / F mower squeaking? #16
Googling...it apparently is Krown. But I don't understand how this product relates to lubing for squeaks.
   / F mower squeaking? #17
That's right, I stand corrected, it's with a K, thanks Jcummins.
This Krown stuff is a rust inhibitor and has great lube properties as well... what I was getting at with spraying the fittings is that in our northern climate, things seize up over time, so a bit of preventative maintenance goes a long way to assist with future repairs.... it's like putting never-seize compound on nut & bolt threads when bolting up components that will be exposed to the elements...
Dan
Was it just me or do they mention oiling metal on metal parts in the operators manual????? Just like to know where I missed it.
   / F mower squeaking? #19
That's a good question Sigrams, I know I've read this recommendation many times over the years, but I'm 99% sure it's the Kubota manuals, not just for F series but for any machine... now where did I see it?
Dan
   / F mower squeaking? #20
Can't say I am a fan of squeaks and rattles either. I have to hunt them down but in general I try and lube all contact points, linkages etc regularly .
Using the appropriate lube can help but on most of the misc metal to metal I think and I prefer to use a light lube like INOX or Lanox which is pretty common here in Australia but WD40 should be OK too. I just avoid having anything to sticky that will attract dirt, dust and grit so that it doesn't turn into a grinding paste.
I do have a bit of a clattering sound when the cutting deck is engaged though, still yet to track it down, just hope it is not in the transmission.
2011 Ford Escape SUV (A55853)
2011 Ford Escape...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
Welcome to the Ranch Decorative Sign (A55853)
Welcome to the...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
2025 Poly Fuel Tank with Electric Pump (A55852)
2025 Poly Fuel...
UNUSED SDLANCH PORTABLE WOOD CHIPPER (A57193)
UNUSED SDLANCH...
