LX178 Lift Assist Very Stiff
   / LX178 Lift Assist Very Stiff #1
khodgens
Member
PAGOSA SPRINGS
LX178
Is there an adjustment for the lift assst. Mine is so hard I have to nearly get off the tractor and use both hands to move the lever forward or back. I wouldn't think it should be this hard to operate.
   / LX178 Lift Assist Very Stiff #2
Have you checked to see if the spring is intact?
   / LX178 Lift Assist Very Stiff #4
Be careful with the spring.
This is not that good of a photo, but I think that is where you will see the spring.
You will need the deck off.
BBO thanks for the photo. I got side tracked and we're headed to the mountains tomorrow for 3-4 days so I'll check when we return and be sure to update my thread.
Thanks!!
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
10' CONTAINER (A52706)
1981 LINK BELT HSP 8028 (A58216)
1981 LINK BELT HSP...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
2019 GALYEAN...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
