A dye for spraying weeds
   / A dye for spraying weeds #1
Walkin Horse
Chesterfield Va
Shibuara Ford New Holland 555D NH Workmaster 55
I was out today spraying weeds. I have a bad jinsom weed problem. The fence lines are easy to keep track of but the ones that are growing random in the open are hard to keep up with. Does anybody use a dye to keep up with what's been sprayed. I'm spraying with a 25 gal sprayer in the back of my mule. I try to look for wet leaves but sometimes you miss ones. I figure there's places I'm over spraying and places I'm missing. So if they had a little temporary color it would help.
   / A dye for spraying weeds #2
TSC carries a dye for use in spraying. Most farm supply stores will carry that product or something similar.
STeve
Thanks. I never checked. I was just out riding and spraying and I thought of this. Thanks
   / A dye for spraying weeds #4
They also carry a blue dye for ponds which works great for spraying and is significantly cheaper than the dye for spraying is.
   / A dye for spraying weeds #5
The die at TSC is good stuff. A tiny bit of it goes an extremely long way, an ounce will color maybe 25 gallons. Particularly nice is that it disappears after about 30 minutes or an hour; you can't tell tomorrow that you sprayed an area today, but you can tell where you left off 30 minutes ago.
   / A dye for spraying weeds #6
Kinda of a ditto post but I bought a blue dye for using in my back pack sprayer. A little goes a very long way. With my sprayer, too much dye will clog the sprayer so don't use too much. I bought the dye from the farm store.
Later,
Dan
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53473)
UNVERFERTH 330 8...
