Ram 2500 vs 3500 Gooseneck?
   / Ram 2500 vs 3500 Gooseneck? #1
HK45
Gold Member
Bethlehem, Pa
Kioti nx6010 loader backhoe
Im looking at getting a new truck. I have 2 gooseneck trailer one a 14ft dump and the other 25 deckover gooseneck. With trailer and what I tow I'm around 13,000. Im thinking of just getting another ram 2500 vs the 3500. I really liked the coil spring setup on the Ram. They have the same tow rating of 17,000 something and a gcwr of 25,000. The payload bed is the only different. If only towing a few times a month is it worth going to the 3500. thanks
   / Ram 2500 vs 3500 Gooseneck? #2
What's the price difference? Are you sure the tow ratings are the same for the 3/4 and the 1 ton?
   / Ram 2500 vs 3500 Gooseneck? #3
I know when I went from a F250 to a Single Rear Wheel F350 it was night and day. The 1500# payload jure mad the avaliable tow rating a lot more usable and comfortable. The F250 squatted about 6", the F350 maybe 2"
No comparison.
Chris
   / Ram 2500 vs 3500 Gooseneck? #4
Here are some things to consider. The higher GVWR of the 1 ton will allow you to increase the tounge weight which will allow you to place the load on your flat bed closer to the truck to take weight off the rear trailer tires. The down side is that if you are using this set up for work or to make money the 350 will put you in CDL territory.
Okay got specs but its for the 14 ram 2500 GVWR 10,000 PAYLOAD 2,180 BASE WEIGHT 7,825 FRONT WEIGHT 4,811 BACK 3,014 GAWR FRONT 6,000 REAR 6500 GCWR 25,000 TRAILER MAX WEIGHT 17,010 THIS IS FOR THE 3500 SRW GVWR 11,500 PAYLOAD 4,020 BASE WEIGHT 7,483 FRONT 4,520 REAR 2,963 GAWR FORNT 5,500 REAR 7,000 GCWR 25000 TRAILER MAX 17,350. How to you figure pin weight?
   / Ram 2500 vs 3500 Gooseneck? #6
As you can see the 3500 has 1500# more payload capacity and 500# more rear axle capacity.
To figure pin weight on a again it's usually about 20%. So let's keep the math simple. Say you got a 5K trailer and 10K load for 15,000# total. 20% of that would be 3,000#, well within the 3500's capacity but over the 2500's
If you bumped it up to the max 17,000# limit 3,400# would be your pin weight.
I'm not a fan of 3/4 ton trucks. Had 2 and just way to easy to overload and most just will not actually the max trailer weights because of the limits on pin weight.
Chris
whats the max pin weight on the 2500?
is the 2180 the pin weight max?
   / Ram 2500 vs 3500 Gooseneck? #9
I went with a 3500 SRW and it does pretty good with a heavy loaded trailer, but really doesn't compare to my dad's 3500 DRW. It's definitley more stable when hauling heavy loads.
   / Ram 2500 vs 3500 Gooseneck? #10
I have a '14 2500 Cummins. The rear coil springs are the cats meow!
I used to have a 2007 5.9 3500 SRW and my dad had a 09 2500. Back then, I would take my one ton over the 3/4 ton all day long. Now the tables have turned and I have the 2500 and my dad has a '14 3500 SRW. The main reason I bought a new truck is for the coil spring rear suspension. It performs very well and is incredibly underrated. Obviously Ram needs to sell 2500s and 3500s so I'm a firm believer that its just numbers on paper. I like how my truck handles loaded and empty better than my dad's truck. The new 3500s don't have a helper springs on top like my 07 so the main pack has to be stiffer to make up the difference. To me, it feels like the tires are at 110 psi on the one ton compared to my 3/4 ton.
Not to be cliché, but the coil suspension on the 14+ 2500s are the perfect combination of ride comfort and load stability. Here's my truck with 2,000 lbs of fertilizer in my truck. Thanks to my toolbox, the load is mostly behind the axle. Even still, the truck only squat about 1 3/4".
Don't think I'm just a fanboy who uses my truck as a grocery getter, my truck gets put to work.
Also, you can't compare other truck brands' 3/4 and one ton models as they have nothing in common (just watch the comparison videos on youtube). My cousin is a farmer down here and he almost got rid of his F250 because the suspension was so weak. He had to add air bags and its still subpar.
There are more pictures and reviews over on the Cummins forum http://www.cumminsforum.com/forum/2013-general-discussion/1002186-pictures-loads-rear-coils.html
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A58375)
UNUSED INDUSTRIAS...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2022 Ford F-150 Pickup Truck (A56858)
2022 Ford F-150...
2024 Yakta YXR710 Zero Turn Lawnmower (A57453)
2024 Yakta YXR710...
UNUSED FUTURE 32" HYD TILTING BUCKET (A58376)
UNUSED FUTURE 32"...
