Ford 2000 Carb kit
   / Ford 2000 Carb kit #1
CAPEHORN
Selma, Al
Ford 2000
Hello! This is my first post and I love this site! I have a Ford 2000 model# B1023B and Serial # C479709. I think its a 1975 model. It has a Zenith Carb. and the Tab numbers are 02 07 and 13915B and E1NNDA. I have been searching for a carb. Kit. Every kit I have looked at, the main gasket that splits the carb into, is not the same as the gasket on the carb now. The closest kit I can find is one for a Zenith 13915 not a B. Would this kit work for me?? The Carb is leaking gas out the weep hole. The needle and seat look new. I have cleaned the entire carb and all the jets, but it is still leaking. The float does not leak and is good. I have tested the float and needle and It seems to be working good. My though is the gasket is not sealing off the gas correctly and gas is spilling over into the intake and out the weep hole. Thank you for all your help!
   / Ford 2000 Carb kit #2
If you just need a gasket go to any auto parts store and get a roll of gasket material and then get a leather punch and make your own. Ed
Hey Ed,
This morning I made a new gasket just what you said. I will try it tomorrow. I am worried about why I can not find the right kit for this carb. The float and needle that are in the carb. may not be the correct parts. I bought this tractor last year and it has always leaked fuel. I have to turn the fuel valve off and let it run out of gas or it will leak out all the gas in the fuel tank. I looked for additional numbers on the carb. but didnt find any model numbers.
   / Ford 2000 Carb kit #4
It sounds like more of a float adjustment problem. The fuel level in the bowl should be approx. 1/4 of the full depth of the bowl, from the top of the bowl, when the needle valve shuts it off. If leaving the fuel valve open, and it will drain the tank, there is a problem with the float, or it's proper level setting, It could be hanging up on something, or just needs adjusted.
When I head back out to the shop, I'll see if my manual shows the float measurement for the Zenith. My '65 model has the Holley, and I know it has info on it, just not sure if it covers the others. Maybe this thread will catch Soundguy's eye, and he can chime in on the subject.
   / Ford 2000 Carb kit #5
Hey Ed,
I have got into a habit of always turning off my fuel tank when I park either one of my Ford tractors. Those gravity fed tanks can fill up my crankcase if the needle valve ever sticks open. I've had to change my oil more than once, because I forgot to shut off the fuel supply. I also try to remember to turn the fuel off (and many other gas engines too) and let the engine continue to run until the carb is empty if I think it may be a long time before use it again. I don't like the though of fuel gelling in my carb or leaving a film inside the carb if it evaporates out.
Thank you for taking the time to do that. I also wanted to adjust the float, just was not sure of where I should bend the float at and how much to bend it. The float looks the be almost level.
Thanks MichellB, Glad to here someone else does the same as I do. The tractor will not crank now because of all the flooding. Funny thing is, once I crank the tractor it does not flood out. Only when sitting. Maybe when the tractor is bouncing around when I drive it, the float and needle works.
   / Ford 2000 Carb kit #8
Thanks DJ54,
That is a great website. I will look around and see if I can find the kit that will fit my carb. The explosive view that you sent me is different from my carb. I will try to upload a pic of the gasket so you can see the difference.
Well, I got a picture of the gasket but I can't upload. The website tells me that the upload has failed.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2005 Ford F-150 Pickup Truck (A51692)
2005 Ford F-150...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2011 FORD F-650 ROUSTABOUT TRUCK (A52472)
2011 FORD F-650...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
378645 (A51573)
378645 (A51573)
